Question About Mixing Quick Setting Cement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-13-2010, 02:38 PM   #1
Question about mixing quick setting cement
I got some Quikrete commercial grade quick setting cement to fill in some nail holes and other small marks. I got a small bucket of the stuff, like 10 pounds or something like that.
To mix it, it says mix 5 and 1/2 parts cement to 1 part water. Is this by weight or volume?
So for example would I mix 5 and 1/2 cups of cement would I mix 1 cup of water with it?
ajtool is offline   Reply With Quote
Old 09-13-2010, 04:12 PM   #2
Rewards Points: 5,336
What type of mix is this? Concrete, sand or mortar? Nail holes in what material?
Ron
Old 09-13-2010, 07:07 PM   #3
Ron
this stuff: http://www.quikrete.com/ProductLines...tingCement.asp
Nail holes IN concrete. Yes, you read that right
Old 09-13-2010, 08:23 PM   #4
King Construction Inc.
when i mix hydraulic cement I ALWAYS mix it very soupy its not really going to hurt anything but gives you more time to work with it and is a little easyer to pour in the holes... and i highly recommend mixing little bits at a time
nking is offline   Reply With Quote
Old 09-13-2010, 08:43 PM   #5
Rewards Points: 276
This sounds like good advice. I did notice on the Quickcrete data sheet that reducing the water will hasten set time. Maybe a little trial and error with small amounts will be easier that trying to figure out 5 1/2 parts mix to 1 part water.
Jim F is offline   Reply With Quote
Old 09-22-2010, 12:58 PM   #6
So.... I mix this stuff up by volume and NOT by weight?
Tags
cement , concrete , quikrete
Mixing paint - dumb question hyunelan2 Painting 5 04-09-2010 04:33 PM
New member, mixing valve question. morrow Plumbing 4 02-25-2010 08:55 PM
general question on portland cement rtoni Building & Construction 2 07-11-2009 08:32 AM
Refinishing cement garage floor question redpen Flooring 1 05-31-2009 10:07 PM
Cement Board Install Question AVTechMan Building & Construction 9 03-19-2009 02:45 PM
