Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-19-2009, 09:39 PM   #1
Default Question about Drills?
Hello there. I have a quick, but sort of strange, question. I am a big fan of apple cider and have recently have been designing and building a grinder and press. They are both done and ready to go (work well, too), but I have a problem with the grinder.
My grinder is VERY similar to the one seen here. (yes, I understand a food processor would work better, but I am just getting into the cider scene!)
Currently, I am cranking the grinder by hand, which really takes a toll on the arm after grinding a few dozen apples. I was thinking (instead of using a large pulley and motor like the link above) of using a variable speed drill (110v, not battery) and running it low speed to power the grinder (either the drill normally, or taking it apart and salvaging the motor).
Do the pro DIY'ers think it will work? I don't foresee any problems with it as the people often use 18v drill motors and batteries to power robots (BotsIQ in schools, for example), and I am sure they are used for other things.
Just figured I would run it by you all... thoughts? Any other ideas?
Thanks in Advance - Mike (ste6168)
edit- I didn't post in the the "tool" section, becuase its not a direct tool question, per se...
ste6168 is offline   Reply With Quote
Old 10-20-2009, 01:15 AM   #2
keep in mind that a drill, cordless or otherwise wants to operate at a certain speed, if it runs too slow the motor will cook, if it runs too fast the bearings will cook. That big pulley is made to allow the drill to run at the speed it was made for and since the primary is very small and the secondary is very big it makes the drill run fast and the press run slow, "this is the way of things"
Salem747 is offline   Reply With Quote
Old 11-03-2009, 04:35 PM   #3
Look at the torque rating of the drill.
Most corded drills don't have a lot of torque.
A good torque rating for a cordless drill is 400 inch pounds. If your handle is 12 inches long, then divide by 12: 33 foot pounds. Hang a 33 pound weight from your handle and see if it turns. If not, then you need more torque.
A long time ago I used a motor out of a paper shredder to turn a grain mill. It runs at 60 RPM and has more than enough torque.
Thanks for that picture of the apple grinder. I might make one of those. This season I bought a garbage disposal to grind my apples, but the thermal overload kicks in after a half bushel or so. Maybe I'll get the old shredder motor and connect it to a grinder like the one you linked to.
How do you prevent the oak from spinning on the axle?
pyper is offline   Reply With Quote
Old 11-03-2009, 06:42 PM   #4
Master General ReEngineer
Ayuh,... 1 of these, chucked right to the axle will do the job....
Old 11-04-2009, 05:45 PM   #5
ste6168 [Mike]:
While you will see many applications of drills doing work other than drilling, you should be aware that drills are made to exert a force in the downward mode, not in a latera [side ways] mode.
You will also see screw drivers used as levers and as chisels too. Those mistakes are better understood.
If you are intending to use a good drill, I expect that it will wear prematurely and you can expect drill failure.
Drills used as a sanding tool where the sanding application is from the side suffers the same fate.
Belt driven motors should have bearings to accept that side load so my suggestion is that you use an old furnace motor or some cheap second hand motor if you are experimenting with your cider manufacture.
Hope this is of help. Not intended to throw cold water on your idea but rather to forewarn you on the drill use.
Good luck,
Woodie
george woodie is offline   Reply With Quote
Old 11-06-2009, 02:17 PM   #6
George makes valid points about laterally loading a drill, but in this case I don't see where the lateral load comes from -- the oak "bearings" should take all the lateral load.
I think the motor is a better idea anyway.
Old 11-06-2009, 02:23 PM   #7
Bondo handled the lateral load problem with his suggestion. The Milwaukee angle drill would do the trick to.
RegeSullivan is offline   Reply With Quote
Old 11-06-2009, 11:37 PM   #8
I don't think there actually is a lateral load problem, but does the Milwaukee have real bearings on the shaft? Most drills only have sleeve bearings.
Old 11-07-2009, 07:11 PM   #9
I really don't know about the bearings. I have had it a long time and have never had a problem. It seems to take a abuse pretty well. One of the things I like about it is you can reverse the the angle shaft to change the gearing. I have never done it but I believe you can remove the angle and use it as a straight drill.
My dad had one for years... He was a plumber and after the first one disappeared off the truck he chained it to the seat in the van along with the Milwaukee Sawzall.
Rege
Old 11-08-2009, 08:32 AM   #10
Ayuh,... The Hole-Hawg pictured does,... Big'ins....
Along with 2 speeds,+ reverse...
More On This Topic
On behalf of Expert Village I'm Terry and today I?m going to show you how to use a hand held grinder. On the air tools you can use three in one oil or you can get actual air tool oil at most auto part stores or your hardware store. You drop one to two... Read More »
Hello my name is Melissa and on behalf of Expert Village today I'm going teach you a couple of different ways to make a perfect cup of hot apple cider. So in the first clip we talked about our ingredients so in this clip we're going to take all the... Read More »
Next thing we're going to do is we're going to drill the B note. So, we're going to take our power drill here. Make sure it's plugged in and has power. We're going to be very careful as we drill this copper pipe here. Again, at the top about a quarter... Read More »
Hi, my name's Curtis Enlow and on behalf of Expert Village, I'm going to show you how to plan, setup and equip a work area for radio controlled models. Ok, let's talk about power tools. One of the old standards is the Dremel motor tools and these can be... Read More »
Now we're ready to drill the F. As we've done before we're going to put it in a pipe holder on our grip, tighten it just enough to hold it steady. Going to get some power into our drill. We're going to go a quarter inch down. Be very careful of the drill... Read More »
Basement Renovation Question KUIPORNG Remodeling 235 08-26-2008 10:19 AM
hrv question indep HVAC 3 07-18-2008 12:39 AM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 11:10 AM
New service Question Onytay Electrical 1 10-24-2007 07:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-12-2007 12:17 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
