Question About Conrete Board - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-14-2010, 10:19 AM   #1
Question about conrete board
So I'm doing my balcony and so far I have attached 3 pieces of concrete board to the subfloor, however I didn't notch the thinset I just applied it with the flat side. Is this going to be a problem later?
I'm talking about the concrete board to the subfloor not tile to board.
snowcow is offline   Reply With Quote
Old 10-15-2010, 08:22 PM   #2
remodeling pro
Most likely will not cause a problem. The notches help for two things. First, they allow for a deeper buildup of thinset so that you still get support in any low areas you span, while the empty spaces provide area for the excess thinset to go as you span the higher areas. Lightly tap around with a hammer on the pieces you have down to see if you can detect any large areas that sound hollow. If so, I would cut it out and reset that area, otherwise continue on , using a notched trowel.
troubleseeker is offline   Reply With Quote
Old 10-16-2010, 11:14 AM   #3
Rewards Points: 5,336
How did you fasten the cement board to the subfloor? As to the notching, I think there could be an issue. You can't get a consistant level of thinset on the surface.
Ron
Old 10-16-2010, 12:05 PM   #4
Registered User
Rewards Points: 526
If exposed to the elements, rain, etc., I hope you water-proofed it all before the backer board: http://www.johnbridge.com/articles/ditra-balcony/
The notched pattern leaves ridges/bridges than span the low spots and compress in the high spots, with it flat is a inferior application. They make up for the inconsistency in the sub-floor to make a uniform surface for the tile (which don't bend or flex much without popping loose). Is the floor pitched to drain or fully covered above?
Gary
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 06:29 PM
Tile over Particle Board dgun357 Tiling, ceramics, marble 2 01-16-2010 08:00 PM
rigid foam board and height ctkeebler Building & Construction 4 01-09-2010 02:42 PM
particle board question??? Axhammer Flooring 27 01-04-2010 07:08 PM
Hardie backer board DXS General DIY Discussions 2 03-17-2009 05:40 PM
