PVC Vs. Composite Decks - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-21-2010, 05:34 PM   #1
Question
PVC vs. Composite Decks
We need to replace the second story deck on our house in TN, and want it to be as maintenance free as possible. We're leaning toward Timbertech XLM which is a PVC, but would like input from anyone out there who has it and from anyone who has a composite they think is wonderful. Any recommendations, opinions, complaints, etc.? Thanks!
Seahag
Seahag is offline   Reply With Quote
Old 12-21-2010, 05:44 PM   #2
SDC
SDC's Avatar
Seahag
I install a few deck and my personal favorite is AZEK Decking (PVC) but that is my opinion.
This question is like asking what is the best truck (Ford, Chevy, Dodge) you will get all different answers.
David Cookman
www.SDCookman.com / FaceBook
SDC is offline   Reply With Quote
Old 12-21-2010, 05:52 PM   #3
Reply to David
True enough that everyone will have their own opinion, but networking always results in getting info one didn't have before. I hadn't considered Azek, but will check into it. Thanks!
Old 12-22-2010, 07:46 AM   #4
I highly recommend going with a PVC. Azek and tt are both made from the exact same raw material. Axel is 100 percent PVC and tt is a cap of PVC. I thnk what you want to ask yourself is what type of fastening system you plan on using. Let me know and I might be able to direct you
dvatt is offline   Reply With Quote
Old 12-22-2010, 09:06 AM   #5
I have used trex and am satisfied. I understand it is a composite of wood fiber and HDPE. It can, and does, stain a bit, but this does not bother me much. It can also fade over time. I understand that is true for most deck materials.
No deck will look good over time without cleaning.
oberkc is offline   Reply With Quote
Old 12-22-2010, 10:23 AM   #6
Pvc can b cleaned w just water and a rag
Old 12-22-2010, 10:24 AM   #7
Rewards Points: 5,336
Composite decking will get hot in the Sun. The darker the decking, the hotter it will be. Darker decks will be too hot to walk on with bare feet and too hot to sit on with shorts.
Ron
Old 12-22-2010, 10:39 AM   #8
Thanks dvatt & Ron6519 ~ both good considerations. At this point, I'm leaning toward Timbertech XLM in SandRidge. Still uncertain re railings, though. Would the composite be okay for railings (to save $$), is PVC the way to go, or is power-coated aluminum more durable? Comments/suggestions?
Old 12-22-2010, 10:41 AM   #9
We're planning on using the hidden fastener system.
Old 12-22-2010, 12:01 PM   #10
I would go w tt then. Tigerclaw makes their hfs for tt and it's the best
Old 12-22-2010, 12:18 PM   #11
Thanks, dvatt. Now to decide on the railing material: Composite vs. PVC vs. power coated aluminum.
Old 12-22-2010, 12:38 PM   #12
Will your deck have stairs? Clipped corners? Do you want white railings?
Old 12-22-2010, 12:50 PM   #13
No stairs. Not sure of color ~ either white, bronze or black. Will the latter get hot in TN sun if made of certain materials mentioned?
(we live in MI now; that's not an issue here)
And what's a clipped corner?
Old 12-22-2010, 12:59 PM   #14
White carries the longest warranty. Clipped corners r when u have 45 degree corners not 90 like a square
Old 12-22-2010, 01:19 PM   #15
Thanks, dvatt ~ good things to take into consideration.
ptw Rim joist = composite fascia board max_wonder00 Building & Construction 3 10-15-2010 07:05 PM
Composite deck with wood railings? Or ditch the composite and go all wood? CoconutPete Building & Construction 5 07-29-2010 12:30 PM
how to attach composite deck to steel TazPapa Building & Construction 3 05-31-2009 08:45 PM
Hybrid Deck - Is Pressure Treated + Composite Feasible? kyassassin Building & Construction 4 01-15-2009 08:33 PM
fence problems? composite decks? maml247 Landscaping & Lawn Care 6 03-29-2007 02:10 PM
