-   -   PVC vs. Composite Decks (http://www.diychatroom.com/f2/pvc-vs-composite-decks-90194/)
Seahag 12-21-2010 06:34 PM
We need to replace the second story deck on our house in TN, and want it to be as maintenance free as possible. We're leaning toward Timbertech XLM which is a PVC, but would like input from anyone out there who has it and from anyone who has a composite they think is wonderful. Any recommendations, opinions, complaints, etc.? Thanks!
Seahag
SDC 12-21-2010 06:44 PM
Seahag
I install a few deck and my personal favorite is AZEK Decking (PVC) but that is my opinion.
This question is like asking what is the best truck (Ford, Chevy, Dodge) you will get all different answers. :eek::laughing:
Seahag 12-21-2010 06:52 PM
Reply to David
True enough that everyone will have their own opinion, but networking always results in getting info one didn't have before. I hadn't considered Azek, but will check into it. Thanks!
dvatt 12-22-2010 08:46 AM
I highly recommend going with a PVC. Azek and tt are both made from the exact same raw material. Axel is 100 percent PVC and tt is a cap of PVC. I thnk what you want to ask yourself is what type of fastening system you plan on using. Let me know and I might be able to direct you
oberkc 12-22-2010 10:06 AM
I have used trex and am satisfied. I understand it is a composite of wood fiber and HDPE. It can, and does, stain a bit, but this does not bother me much. It can also fade over time. I understand that is true for most deck materials.
No deck will look good over time without cleaning.
dvatt 12-22-2010 11:23 AM
Pvc can b cleaned w just water and a rag
Ron6519 12-22-2010 11:24 AM
Composite decking will get hot in the Sun. The darker the decking, the hotter it will be. Darker decks will be too hot to walk on with bare feet and too hot to sit on with shorts.
Ron
Seahag 12-22-2010 11:39 AM
Thanks dvatt & Ron6519 ~ both good considerations. At this point, I'm leaning toward Timbertech XLM in SandRidge. Still uncertain re railings, though. Would the composite be okay for railings (to save $$), is PVC the way to go, or is power-coated aluminum more durable? Comments/suggestions?
Seahag 12-22-2010 11:41 AM
We're planning on using the hidden fastener system.
dvatt 12-22-2010 01:01 PM
I would go w tt then. Tigerclaw makes their hfs for tt and it's the best
Seahag 12-22-2010 01:18 PM
Thanks, dvatt. Now to decide on the railing material: Composite vs. PVC vs. power coated aluminum.
dvatt 12-22-2010 01:38 PM
Will your deck have stairs? Clipped corners? Do you want white railings?
Seahag 12-22-2010 01:50 PM
No stairs. Not sure of color ~ either white, bronze or black. Will the latter get hot in TN sun if made of certain materials mentioned?
(we live in MI now; that's not an issue here)
And what's a clipped corner?
dvatt 12-22-2010 01:59 PM
White carries the longest warranty. Clipped corners r when u have 45 degree corners not 90 like a square
Seahag 12-22-2010 02:19 PM
Thanks, dvatt ~ good things to take into consideration.
