PVC Pipe Dangers?? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-25-2006, 04:57 PM   #1
PVC pipe Dangers??
hello, i have looked all over internet to find accurate and unbiased information, however im having troble finding anything meaningfull, im hopeing the experts here could help me out... My questions is, is how dangerous is pvc pipe really? can it be kept in house around animals and people ? are there any dangers from cutting pvc pipe? chemical wise? also should a dust mask be wore when cutting?, i understand thats its dangerous to heat pvc pipe, about what about cutting? Any internet links would also be appericated, thanks
jwil4 is offline   Reply With Quote
Old 12-25-2006, 06:42 PM   #2
pvc pipe is plastic .it doesnt hurt animals to be around it i wouldnt feed it to them.its alot like the plastic bowl you may feed a animal in
pvc is not like lead or asbestis
trollmastergeneral is offline   Reply With Quote
Old 12-25-2006, 07:01 PM   #3
jproffer's Avatar
Rewards Points: 706
However...If it burns, it puts off toxic fumes. Naturally I realize you're not PLANNING to burn your house down...but realistically, I don't think if the unthinkable happens you're going to remove all the pipe before you get out. In some states regular PVC is not allowed within the "footprint" of the house, for this reason.
Regular PVC can't be used on hot water lines anyway but CPVC can so I can't think of any overwhelming reasons to use regular PVC anywhere. If you get PVC you just have to keep seperate piles...make sure you don't accidentally use regular PVC on a hot water line....make sure you don't grab the CPVC glue and put together regular PVC pipe and fitting (or vice versa)...and so on.
jproffer is offline   Reply With Quote
Old 12-25-2006, 09:54 PM   #4
remodeling pro
I would not worry about any health concerns here, but check with the local inspector before plumbing with it, as many localities do not accept pvc for pressure lines inside a residence. If you use it, do not skip the primer, they will fail you if so.
troubleseeker is offline   Reply With Quote
Connecting PVC to Galv Pipe fitting for Drain froddan Plumbing 19 02-28-2010 04:33 PM
Use of coupling fitting on gas pipe Fred Plumbing 3 01-28-2007 07:13 AM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
