PVC Cement Question - The Glue Doesn't Seem To Work - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-19-2011, 05:25 PM   #1
Rewards Points: 16
PVC cement question - the glue doesn't seem to work
So I have this inflatable boat from Sevylor, which developed a small leak. I bought some regular clear PVC cement from Home Depot in hopes of fixing it with the included patch kit.
I thought that the cement was supposed to slowly become very sticky, at which point I'm supposed to stick the patch onto the boat and apply pressure. But here's the problem -the glue doesn't get all that sticky, eventually turns into snotty strands which look like semi-dried clear silicone caulk. And it never grabs on, I attempted to fold a patch in two and hold it like that, but nothing came out of that. The boat is seems to be made out of PVC and the manufacturer speaks of "PVC glue" in their repair instructions...
What am I doing wrong? Old cement? Wrong kind of cement? The cement instructions say "if jello-like, do not use", but the glue is not jello-like, it's thicker than water, but flows freely.
whiskers is offline   Reply With Quote
Old 05-19-2011, 07:30 PM   #2
Rewards Points: 5,336
Didn't the repair kit come with adhesive? If not, call them to get the name of the correct material.
Did you use PVC for pipes?
Ron
Old 05-20-2011, 07:43 AM   #3
Rewards Points: 16
Ron
No, it didn't. The kit mentioned either PVC glue or proprietary SeamSeal or something. No, I didn't use the PVC glue for pipes.
Old 05-20-2011, 11:27 AM   #4
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
Not sure but isn't it something like contact cement where you apply to both surfaces allow to dry to a not sticky state and then put the patch on?
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
gravel tar roof repairing mazizbit Roofing/Siding 7 04-09-2012 09:52 AM
Cement Board to Green Board Question ryan5068 Tiling, ceramics, marble 10 05-12-2010 06:29 PM
5/8" Fireboard (Paint) meets 1/2" Cement Board (Tile) LeviDIY Building & Construction 9 02-09-2010 09:41 PM
Foundation Patch: Hydrolic Cement?? roztom Building & Construction 38 09-07-2008 10:22 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
