Putting A Window Fan In The Attic - Fire Hazard? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-18-2012, 07:48 PM   #1
Putting a window fan in the attic - fire hazard?
Can putting an electrical window fan in an attic cause a house fire? I hung mine from some wire right in front of one the side vents to blow out the hot hair. The fan really helps, but I'm not sure if it has a thermal cutoff or not, or if it would heat up in the event of motor failure. Any opinions on this?
Alcyone is offline   Reply With Quote
Old 06-18-2012, 08:40 PM   #2
Rewards Points: 6,652
It will run either until you flip off the switch or breaker downstairs, or when the motor burns up, or the plug end of the extension cord gets too hot. Which in turn I hope you like guys and gals in breakout gear, and nice pretty Red or Yellow trucks carrying big hoses.
You really only need to keep the windows open if there is no venting up there. As for insulation in the attic, to help keep the living space below cool or hot in the winter, is there any?
As for fans with thermal cutoffs, you can buy the cutoffs separate without buying the attic power ventilator. A Power vent for a attic runs around $90 at the most.
Old 06-18-2012, 08:58 PM   #3
Rewards Points: 13,300
Or install ridge vents and never need a fan with a motor on it again.
Old 06-18-2012, 10:26 PM   #4
Too Short? Cut it Again!
The old fashioned wind turbine air extractors work fairly well too. There are also electric generating ridge vent and fan combinations that not only extract hot air from the attic but provide electricity.
The only problem with open vents or turbines is they stay open in a fire and can create draft to fuel flames.
As mentioned, an attic fan with heat cut-off will not set you back that much and you can hard wire it properly. Running a box fan plugged into an extension cord might work but is dangerous. It is a classic example of the wrong tool for the job.
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 09:49 PM
WARNING Kenmore/Frigidaire range model 790.96613409 FIRE HAZARD alfredtgator Appliances 3 12-09-2011 10:30 AM
Old house, hot attic, one window Chuckw Roofing/Siding 5 06-21-2011 06:53 AM
Wiring OK? Fire hazard? Wirefire Electrical 19 12-15-2009 02:08 PM
Attic Window cibula11 Building & Construction 13 03-12-2007 10:47 AM
