Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-23-2012, 04:40 PM   #1
purge fan, central air
My purge fan will not shut off. 7 yr old american standard unit. Suggestions?
fcm 1200 is offline   Reply With Quote
Old 02-23-2012, 05:01 PM   #2
BIGRED
Get yourself a furnace guy. The purge fan when working properly is to clear the air in the fire box prior to, during, and after combustion. If it runs all the time just by applying power then you have a problem with the furnace control board.
Grampa Bud is offline   Reply With Quote
Central Air Conditioning running all day quaildog HVAC 26 03-14-2011 06:02 AM
Central Vac problem strongbow Electrical 4 10-23-2010 09:49 PM
Boiler Zone Purge Valves - Anything special? WaldenL HVAC 4 08-14-2009 09:24 AM
adding central air poger67 HVAC 3 04-28-2009 10:58 AM
Central vac, freezer, and gas water heater on same circuit? curls00 Electrical 7 03-10-2008 10:57 PM
