Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-26-2009, 10:06 AM   #1
protective concrete base for wood stove
I have removed 4 -5" of concrete and rock from the surface of a living room floor. Way to much weight
. Would like to try an 1 1/2 inch pad of concrete with stucco mesh reinforcement as a replacement surface. Also would like to create a stone looking texture in the concrete for rustic effect plus color the concrete as well. I do not want to use ceramic tile. If anyone has played with this option and has had good results, I would appreciate hearing from you.
Last edited by standingeyes; 04-26-2009 at 10:07 AM. Reason: lacking critical info.
standingeyes is offline   Reply With Quote
Old 04-26-2009, 10:09 AM   #2
Sorry forgot something vital. this concrete pad will go under a wood stove. thanks.
Old 04-26-2009, 11:01 AM   #3
Chicago, IL
Michael Thomas's Avatar
Take a look here: http://www.hearth.com/econtent/index...Hearth_Design/
Michael Thomas is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 36 08-05-2012 11:43 AM
Brace wall on concrete Base Elecman Building & Construction 6 10-30-2008 05:33 PM
Extending an existing concrete garage base alan tomlinson Building & Construction 2 10-28-2008 03:26 PM
landscaping backyard with Pavers - needs concrete base? sundar Landscaping & Lawn Care 7 10-09-2008 08:28 PM
Pouring a concrete slab - Do I need a 4" gravel base? tokuzumi Building & Construction 2 11-27-2007 08:40 PM
