Protecting Particle Board Under Sink - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-05-2011, 05:53 PM   #1
Sycamore Inn's Avatar
Rewards Points: 87
Hi ~
I have had a slow leak under my kitchen sink. The particle board did get wet but dried out pretty quickly and I don't think it needs replacing.
What is the best method of protecting the particle board in the event I have another water leak? Would Epoxy work? Any other suggestions?
Barbara
Sycamore Inn is offline   Reply With Quote
Old 10-06-2011, 12:39 AM   #2
Rewards Points: 1,092
Epoxy is water proof; so are several layers of paint. Any way to construct/buy a drip pan? A baking sheet may work. I had one sink that was impossible to seal w/out re-doing some awkward plumbing, so I put a pan under it for a few years till I got to the redo.
Old 10-06-2011, 06:53 AM   #3
PoleCat's Avatar
Rewards Points: 1,652
A place I used to work had bare particle board under the sinks. When ever we flipped an apartment we installed a sheet of floor vinyl. Looked good and won't stick to stuff.
PoleCat is offline   Reply With Quote
Old 10-07-2011, 07:13 AM   #4
My kitchen cabinet is also made from particle board. The most common leak over the years has been when the disposal rusts through and starts to leak. I have a baking sheet (as suggested previously) under it now. The front edge of the floor of the cabinet had the most severe damage with the particle board swollen and broken. I bought a pine Wainscoting kit from Lowes for no more $20, IIRC. I cut away the damaged section and used the Wainscoting and a piece of trim on the cabinet floor. I finished with several coats of polyurethane. It did a nice job of repairing the cabinet floor without extensive replacement and $.
David
Jessidog is offline   Reply With Quote
Old 10-07-2011, 09:15 PM   #5
Rewards Points: 87
Thanks for the replies I have a plastic bucket underneath the sink right now but do not want to use a drip pan to solve the problem. I want to seal the board as much as possible and fix the leak then place something over the particle board - plastic - vinyl - whatever.
Thanks again for the suggestions.
Barbara
Old 10-08-2011, 09:43 PM   #6
2-3 coats of an exterior grade polyurethane, such as Helmsman Spar Varnish will seal up the particle board, and protect it from water.
littlecleo is offline   Reply With Quote
Stainless Steel Sink Question jamiedolan Remodeling 3 05-01-2011 07:35 AM
Sealing a particle board subfloor tunaman Flooring 9 01-17-2011 11:00 PM
Tile over Particle Board dgun357 Tiling, ceramics, marble 2 01-16-2010 08:00 PM
Particle board underlayment help diynut Flooring 5 03-07-2006 05:22 AM
particle board / hardibacker fish3211 Flooring 4 08-10-2005 08:32 PM
