Proper Size Hinge - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-29-2009, 01:45 PM   #1
proper size hinge
i am hanging a solid wood extior door what size hinge shoud be used 4 or 41/2 ?
ajjohn is offline   Reply With Quote
Old 10-29-2009, 01:48 PM   #2
ArmchairDIY's Avatar
Some may disagree with me, but you can use either one. More importantly choose quality hinges with bearings in the leafs.
ArmchairDIY is offline   Reply With Quote
Old 10-29-2009, 04:15 PM   #3
Rewards Points: 5,336
Use 3 of either size and as Armchair said, use a good quality product.
Ron
Old 10-29-2009, 05:20 PM   #4
Tired & Dirty
Rewards Points: 83
A old timer taught me if door is solid-core under 7' use 3- 4" ballbearing hinges, 7' & over 3- 4 1/2" ballbearing hinges. Dosent mean he was right or wrong but I have done it that way for the last 35 yrs. and have seen alot of doors hung this way. But I also agree with the other two guys either will work as long as they are quality ball bearing hinges.
evapman is offline   Reply With Quote
Old 10-29-2009, 05:50 PM   #5
When in doubt, check the manufacturer's specs on the hinges. They normally have weight ratings and door sizes.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Proper awg wire size to use? Suzuki91vx800 Electrical 36 06-23-2009 04:18 PM
Tankless water heater proper pipe size? gante Plumbing 5 04-06-2009 02:28 PM
Anyone know proper size for room a/c-heat? Duane 70 HVAC 7 10-04-2008 10:17 AM
Proper size for TJI's Teresa1127 Building & Construction 5 09-15-2008 06:33 PM
Choosing Proper Wire size PowerEight Electrical 15 05-22-2008 12:58 AM
