Proper Layering For Rural Driveway - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-05-2008, 12:53 PM   #1
Rewards Points: 256
Proper layering for rural driveway
Finally finished clearing the area of our vacant land to be the driveway, there are some small mounds we'll level of and a few holes we'll fill in with the Bobcat this weekend. Once we get it roughly flat, how should we proceed with making it suitable for a gravel driveway? My understanding was fill and then gravel, but now I'm hearing there is different types of gravel, sometimes you add a layer of sand, so on and so forth. Experiences?
moneymgmt is offline   Reply With Quote
Old 06-05-2008, 04:08 PM   #2
47_47's Avatar
Rewards Points: 44
My experience, you need a proper base. Our old stone driveway was sinking (150'x15'). I had an excavator replace ours. They removed the top 6-8" of material, relocated it to a low spot and regraded, installed geotextile fabric, installed about 80 ton of a crusher run, compacted and top dressed with a 3/4"-. They excavated, relocated and rough graded the spoils and installed the fabric the first day (6 hours) and finished in 3 hours on the second day. In 2003 I paid $3500. My cost for materials alone would have been around 1500. Even though I have a small TBL and could have done the job, I estimated my time as 7-10 days of solid work, with good weather and with the wear and tear of my machine I paid.
All in all I got a solid drive and a good deal.
47_47 is offline   Reply With Quote
Old 06-05-2008, 04:17 PM   #3
Rewards Points: 256
WOW! Fortunately, we only have about 20 yards that needs to be finished so I'm not sweating doing it ourselves. Let me see if I read your layering correcty: you regraded dirt to get it flat, then put down the fabric, then crushed stone, then 3/4" gravel? When finished how high is the gravel layer raised above the surrounding ground? (I ask for drainage reasons) Thanks!
Old 06-05-2008, 07:32 PM   #4
It probably depends on where your at as to how it is typically done. I'm cheap and wasn't in a big hurry and this worked very well for me. I built up the drive about 2-4" using dirt from a drainage ditch I cut down one side of my property. Let it rain on it a few times and pack it by driving on it after it dries up just enough to not rut it up. Around here we top it with several inches of limestone or crushed concrete. I did about 1300' of driveway like this and it's held up to cement trucks pretty well with just minor repairs after pouring my garage and house. I wouldn't recommend spending too much on it till after your done building. The cement and dump trucks will just tear up your nice driveway if you don't wait.
smcmurrey is offline   Reply With Quote
Old 06-05-2008, 08:45 PM   #5
joed's Avatar
Rewards Points: 11,596
Depending on the type of dirt you should remove a good protion of it. Then fill the hole with gravel.
Some links
http://www.diydoctor.org.uk/projects/Drive.htm
http://www.askthebuilder.com/698_Bui...Driveway.shtml
Old 06-06-2008, 08:26 AM   #6
47_47's Avatar
Rewards Points: 44
The stone is retained on both sides of the drive with short 1" exposed retaining walls. On one side of the drive we have a hill and on the other side I ran 4" Schedule 40 PVC pipe starting at 8" and sloped toward the front ditch. I drilled holes in the pipe. I used the Sch. 40 because that's the access to my back yard for equipment. The driveway slopes 1-1" across the 15' from the hill towards the pipe. They didn't put that much pitch on the driveway because of all the stone they replaced.
The height of the stone is at grade and the short exposed walls prevents mixing.
Load Capacity of driveway - Will a dump truck crack it? Deavis Building & Construction 17 03-29-2015 09:43 AM
sloped driveway at 1 family house lk5333 General DIY Discussions 2 02-20-2008 07:37 AM
3/4" Gravel on Sloped Driveway not locking - help? WynsWrld98 Landscaping & Lawn Care 7 10-17-2007 12:02 PM
Driveway Pitch handy man88 Building & Construction 6 09-11-2007 06:15 PM
