Proper Flashing - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-11-2011, 07:10 AM   #1
Rewards Points: 93
Proper Flashing
I have a 3' overhang on the back of my house (2nd story overhang over 1st story). Below the overhang is a concrete slab. I would like to enclose the overhang and make it an outside closet/storage area. How exactly would I do this?
I understand the framing part, my big question is how do I attach to the slab? Do I just bolt the bottom plate into the concrete slab or should I have something else there at the transition (row of brick)? The exterior will be siding. Seems to me that i would not want siding going all the way down to the slab but maybe with proper flashing that is ok?
It will be inspected, but my inspector isn't very knowledgable/helpful.
jsbeckton is offline   Reply With Quote
Old 04-11-2011, 07:45 AM   #2
Not so new
12penny's Avatar
Rewards Points: 520
...you didnt fill out your profile, so we dont know where you are located.
In a northern climate, if attached to the house then frost footers will probably be required.
If not, then bolted to the slab may suffice.
Not sure how code looks at that.
12penny is offline   Reply With Quote
Old 04-11-2011, 09:00 AM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 666
Send a message via Skype™ to AndyGump
Too many variables, do you have stucco, wood siding, crawl space, slab-on-grade etc?
Andy.
AndyGump is offline   Reply With Quote
Old 04-11-2011, 09:07 AM   #4
Rewards Points: 93
Sorry, I am located in Pittsburgh, PA.
The exterior is (will be) vinly siding. The slab runs under the current wall to the garage on the other side.
Nothing under slab.
Old 04-13-2011, 06:09 PM   #5
Where I live, if its attached to the house, it requires a building permit. In Pittsburgh its likely that you will have to have a foundation with footings below the frost line.
You should check with your building dept. and see what is required in your area.
Here, if its free standing, it can be mounted on the slab. If its less then 100 s.f. and is free standing, no permit is required.
Proper chimney flashing tg028 Roofing/Siding 8 07-26-2010 03:16 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 10:08 PM
proper steps in wrapping tyvek and flashing windows?? 4just1don Building & Construction 4 11-17-2008 06:10 PM
MW Vinyl windows w/ JChannel + Hardi Board Siding - Proper Flashing? jboeckler Building & Construction 1 09-20-2008 02:55 PM
Proper way to install gutter flashing? Kasfidan Roofing/Siding 3 03-17-2008 12:57 AM
