Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 06-13-2006, 09:01 AM   #1
problems with tiles
I hired a relative to install tiles on the living room last May 05, and already I had to remove over 200 tiles. I'm presently removing and installing more. The real problem is that over an inch of thinset was used to level the floor and since water has sipped through, the grout is cracking and the tiles are coming out. Instead of thinset, can I use portland cement. Also, what is a good grout and sealer to use that can prevent the water from passing through. Help, I'm doing this job myself now.
anthjess10 is offline   Reply With Quote
Old 06-13-2006, 09:20 AM   #2
problems with tiles
How thick is your sub floor?
If the sub floor is too thin than that would allow the tiles to flex and move.
redline is offline   Reply With Quote
Old 06-13-2006, 10:04 AM   #3
Oldguy
Rehabber's Avatar
problems with tiles
1. Why was 1" of thinset used? 2. What is under the thinset?:confused:
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 06-13-2006, 02:16 PM   #4
problems with tiles
This is a recent new 3 fam house constructed with cement floors (cement Planks).
Old 06-13-2006, 09:34 PM   #5
Floorwizard's Avatar
problems with tiles
Thinset cannot and should not be used as a leveler.
Floorwizard is offline   Reply With Quote
Old 07-06-2007, 03:15 PM   #6
problems with tiles
I like to know if it is advisable to use purple sheetrock in shower or tub area instead of cement board.
verakop is offline   Reply With Quote
Old 07-06-2007, 04:41 PM   #7
problems with tiles
This should probably in another thread of it's own, but wether you use water resistent sheetrock or cement board, you still need to water prrof the surface before putting on tiles in a shower enclosure. Redgard or Schluter makes products for waterproofing shower enclosures.
slakker is offline   Reply With Quote
Old 07-06-2007, 09:21 PM   #8
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
problems with tiles
NO, NO, NO.....(!)
- Build Well -
Old 07-14-2007, 11:57 PM   #9
Custom Cabinet Maker
problems with tiles
Atlantic soooooooooooooooooooo right
NO NO NO NO NO NEVER NO NO NO
WONDER BOARD UBER ALLUS ie cEMENT BOARD
jACKm
skymaster is offline   Reply With Quote
Are you having ice problems? Grumpy Roofing 27 02-17-2008 04:51 PM
TrafficMaster grout f.y.i. denman Flooring 16 07-01-2007 04:07 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 08:43 PM
Vinyl Tiles over pre-existing layers Thwiipp Flooring 1 09-05-2006 02:10 PM
problems with tiles anthjess10 General Discussion 1 06-13-2006 09:39 PM
