Problems With Tiles - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-13-2006, 07:55 AM   #1
problems with tiles
I hired a relative to install tiles on the living room last May 05, and already I had to remove over 200 tiles. I'm presently removing and installing more. The real problem is that over an inch of thinset was used to level the floor and since water has sipped through, the grout is cracking and the tiles are coming out. Instead of thinset, can I use portland cement. Also, was is a good grout to use that can prevent water from sipping through. Help, 'm doing this myself now.
anthjess10 is offline   Reply With Quote
Old 06-13-2006, 08:39 PM   #2
Floorwizard's Avatar
Deja Vu
Floorwizard is offline   Reply With Quote
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
problems with tiles anthjess10 General DIY Discussions 8 07-14-2007 10:57 PM
TrafficMaster grout f.y.i. denman Flooring 16 07-01-2007 03:07 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 07:43 PM
Vinyl Tiles over pre-existing layers Thwiipp Flooring 1 09-05-2006 01:10 PM
