Problem With New Entry Lock - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-10-2013, 02:25 AM   #16
DIY staff
Rewards Points: 7,174
I don't see a hole in the jamb behind the strike plate---that could cause problems---
Old 06-10-2013, 05:30 AM   #17
jproffer's Avatar
Rewards Points: 716
Ohh....good eye Mike. At least one of us can see lol.
It does look like it "stops short" doesn't it? If the latch wasn't fully released that could make the lock button hard to turn.
jproffer is offline   Reply With Quote
The Following User Says Thank You to jproffer For This Useful Post:
oh'mike (06-10-2013)
Old 06-10-2013, 06:01 AM   #18
DIY staff
You need to reinstall the old catch plate --the new one does not have enough depth to line up with the hole.
Old 06-10-2013, 07:31 AM   #19
PoleCat's Avatar
Rewards Points: 1,652
The tang that mates with the locking button on the inside knob may be too long. When you tighten down the screws it loads it up with a lot of pressure. Try installing with the screws super loose. If it works freely that way then check the tang to see that it did not get bent then and shorten as needed.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Problem with toilet (vent problem?) branch155 Plumbing 24 03-09-2012 09:37 AM
American Standard intermittent inducer problem with presssure switch warning no such user HVAC 5 12-26-2011 05:20 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Prehung entry door gap problem 1fstws6 Building & Construction 3 03-21-2008 07:45 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
