A Problem With My Tile Fitting - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-27-2011, 11:59 AM   #1
A problem with my tile fitting
I have fitted a wall full of tiles in our bathroom and followed the guides on what to do, however because it was only my second go at doing it, I mismeasured slightly and now have a gap at the top of the wall of around 1-2cm which is too small to put a tile into but leaves a visible gap (keeping in mind the lovely paint behind is bright orange!). Do you have any suggestions of what to do to fix the problem?
Using coving is out of the question and using a tile also is but other than that happy to give anything a go.
Thanks in advance.
barlow1984 is offline   Reply With Quote
Old 07-27-2011, 12:01 PM   #2
why is there paint showing and not tile backer
The older I get the better I was
Old 07-27-2011, 12:07 PM   #3
Well there is some of the tile adhesive showing, I didn't use a tile backing just adhesive onto the wall and then tiles ontop.
Thanks for the quick response
Old 07-27-2011, 01:57 PM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Why is cove or trim out of the question? If it is just along the ceiling covering the orange with a matching paint may make it less noticeable.
Old 07-27-2011, 03:59 PM   #5
in one word, the wife! Coving would really sort it out easily
Old 07-27-2011, 05:23 PM   #6
Rewards Points: 5,336
That about 3/4". Add another layer of 1/2" sheetrock to the ceiling. Skim coat the difference.
Ron
B. Franklin 1759
Old 07-27-2011, 08:21 PM   #7
What type of tile is it? If it's the small 1/8" thick tiles, these can be easily cut to size using a score-and-snap tile cutter. I've successfully cut tiles as narrow as 3/8", though it can be tricky. Thicker tiles are a bit harder to cut by this method (though it can be done); you can rent a wet saw to accomplish cuts that a score-and-snap cutter can't handle.
If you're using larger tiles and using a sanded grout... You can fill a large gap with sanded grout and if it's done properly it looks ok. Helpful if the grout isn't too far off in color though!
Let me know if this helps!
Adam
Athomas7114 is offline   Reply With Quote
Old 07-27-2011, 08:26 PM   #8
DIY staff
Rewards Points: 7,174
If you don't like Rons suggestion (which is a clever save)---could you remove a few rows---then add an accent stripe?
Old 07-27-2011, 11:02 PM   #9
Adam
He's trying to avoid an odd looking solution. Slivers of tile do not look good.
Ron
B. Franklin 1759
Old 07-27-2011, 11:10 PM   #10
If done right it can look acceptable. And likely LESS WORK than a new ceiling!
Gotta say though, I really like the idea of an accent stripe a few rows down, that sounds like the winning answer there.
Old 07-27-2011, 11:20 PM   #11
If you get to the tile before it's up too long, you should be able to pop them off without too much trouble.
The accent tile is a good idea and a way to save the job from looking ill conceived.
Ron
B. Franklin 1759
Old 07-28-2011, 08:34 AM   #12
A Little Of Everything
Rewards Points: 1,364
He could just tell his wife to stick a sock in it, and keep her opinion to herself.
I see no problem with that!
DrHicks is offline   Reply With Quote
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 07:03 AM
Still leak after weeping tile replacement mondaysick Plumbing 3 11-04-2010 09:45 PM
Retaining Wall Weeping Tile Problem cg3459 Landscaping & Lawn Care 3 06-16-2010 07:22 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
Tile roof questions/repairs help please xoroniox Roofing/Siding 3 12-17-2006 03:02 PM
