Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-05-2012, 12:57 PM   #1
Question
Prettifying a Concrete Room - baseboard/quarter round gaps
Hello DIY brain trust,
We have a basement room that is concrete walls and floor. We don't have the money to panel and put in flooring, so we painted it and that was a huge improvement.
My wife would like to add some baseboards or quarter-round trim at the floor in order to improve the appearance. However, the walls are not even and so:
  1. a strip of baseboard would meet the wall in some parts and not in others
  2. the quarterround would need to be more like 35%-a-round because it's not a tight 90-degree angle where the wall/floor meet
I'm wondering if there is anything commonly done in these kind of situations? Some kind of "padding" behind the baseboard/quarterround to smooth it up to the wall, or...? I don't really know what the solution might be.
Here are some pics to illustrate:
raindog308 is offline   Reply With Quote
Old 04-05-2012, 01:59 PM   #2
In a little over my head
Is that base molding? Find one with a profile on the top and plain on the bottom to accept the shoe. Shoe molding is like 1/4 round, but taller vertically than it is thick. It flexes easier than 1/4 round.
Then caulk.
ratherbefishing is offline   Reply With Quote
Old 04-05-2012, 02:04 PM   #3
DIY Enthusiast
sublime2's Avatar
Your going to paint the molding?
Put molding up use caulk to fill any gaps then paint.
Same color caulk as your going to paint.
sublime2 is offline   Reply With Quote
Old 04-05-2012, 02:38 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Grind down the concrete irregularities (with a grinder) and install baseboard using adhesives. Use heavy objects against the baseboard (areas where it may arch/bow-out) to push it against the concrete wall.
When adhesive is dry, apply caulking alond top edges to visibly fill gaps between concrete and baseboard.
- Build Well -
Old 04-06-2012, 07:10 AM   #5
Send a message via ICQ to AcaiBerry
nothing else needs
AcaiBerry is offline   Reply With Quote
Old 04-06-2012, 04:05 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
just as atlantic mentioned. only one other thing when you apply the construction adhesive push the piece of base to the wall the pull it away then restick it.. doing so will make the adhesive more tacky and give it more hold while it sets up
woodworkbykirk is offline   Reply With Quote
Old 04-06-2012, 07:14 PM   #7
Instead of wood base, how about a 4" high vinyl base? It's flexible and will "adjust" to the contours and imperfections of the concrete. Cheap quick way to dress it up a little bit.
If it were me, I'd leave it alone as-is.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Room Air Purifier - which is best? nhart Appliances 16 12-07-2012 07:00 AM
Tips For Pouring Concrete? Root issues? Thoughts? kronic24601 Building & Construction 5 02-14-2011 07:52 AM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 01:03 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Blocks or poured concrete for round tower? silverfrost1 Building & Construction 7 07-13-2007 10:27 PM
