Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-11-2010, 09:49 AM   #1
pressure washer problems
People,
I have a hardly used Honda 2500 psi washer. Just restored the carburetor as it was crudded up with old gas a month ago. Now, the thing was running and just died. Im thinking maybe some dirt in the gas clogged carb parts??
Then I realized there is no gas filter inthis model!! Gees, is this normal guys?? No gas filter? (not saying for sure that this is my problem, though, just a hunch)
Thanks!
noquacks is offline   Reply With Quote
Old 07-11-2010, 10:02 AM   #2
Household Handyman
Depending of IF you have a hose leading from the tank to the carb, then YES, and aftermarket filter can be added. Inline fuel filters are available at most auto parts stores, some big box (K-Mart, Wal-Mart, others) stores also. It does sound as if a small piece of trash has gotten into the carb and stopped up some orifice. If you had removed the carb once, you will need to do it again. Clean all small orifices with a carb cleaner spray bomb and wish for luck. First--I would inspect the inside of the tank for foreign material(s). Even a small amount of rust is your enemy. My way: After draining the remaining gas into an appropriate container, wash the tank out with about a cup of mineral spirits sloshing this around aggressively. I like to use a product containing "Ortho-Phosphate", available at auto paint supply stores cheaply, to further clean out rust and coat the inside of the tank. ALL lines and areas fuel flows must be clean and cleaner. David
Old 07-11-2010, 10:18 AM   #3
Thanks, David. Looks like I will yank the carb again and clean. Also dump the tank. Good chore for a sunday.....
Old 07-11-2010, 12:15 PM   #4
It worked!! Started right up! Thanks!!
Water and drain hookup problems with washer and septic system. Snav Appliances 4 01-27-2010 12:01 PM
Pressure Washer Manifold Replace DIY JIM Tools 3 10-13-2009 08:50 PM
pressure washer leaking ktw101 Tools 2 04-27-2009 03:18 AM
Pressure Washer Repair DAVE_NCSU General Discussion 1 11-13-2008 09:05 PM
Pressure washer advice mntentman Tools 1 09-03-2008 09:36 PM
