| Thurman |
07-11-2010 10:02 AM |
Depending of IF you have a hose leading from the tank to the carb, then YES, and aftermarket filter can be added. Inline fuel filters are available at most auto parts stores, some big box (K-Mart, Wal-Mart, others) stores also. It does sound as if a small piece of trash has gotten into the carb and stopped up some orifice. If you had removed the carb once, you will need to do it again. Clean all small orifices with a carb cleaner spray bomb and wish for luck. First--I would inspect the inside of the tank for foreign material(s). Even a small amount of rust is your enemy. My way: After draining the remaining gas into an appropriate container, wash the tank out with about a cup of mineral spirits sloshing this around aggressively. I like to use a product containing "Ortho-Phosphate", available at auto paint supply stores cheaply, to further clean out rust and coat the inside of the tank. ALL lines and areas fuel flows must be clean and cleaner. David
