Pressure Treated Lumber - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-24-2009, 11:17 PM   #1
Pressure treated lumber
I know pressure treated lumber is supposed to withstand the elements however would it benefit me to treat with Thomsons or something of the like?
rick32 is offline   Reply With Quote
Old 05-24-2009, 11:32 PM   #2
Old School
Willie T's Avatar
Pressure treated lumber is not designed to withstand "the elements". But rather to resist the development of mold in moist environments, and therefore the resulting rot. Unfortunately, it is this very pressure treating process that seems to resist the absorption of almost any finish until enough time has passed that the surface begins to dry out some. This usually takes some months.
Willie T
Old 05-24-2009, 11:42 PM   #3
Registered User
Termite's Avatar
Agreed, the pressure treated material needs to weather-in for a few months before any additional treatment is applied.
Personally, I think anything Thompsons makes is really a waste of money. It won't make the wood last longer, that's for sure. You never see pros using it (or similar products like Behr) for good reason.
My advice would be to go with an oil-based penetrating stain/sealer. Penofin is a high quality product that will actually give you something worth paying for. Their 99% UV resistant stuff in the red can is about $40/gallon, and worth every penny in my experience. It'll help reduce the cracking, surface drying and checking that treated southern yellow pine is known to suffer. It comes in about a dozen shades including clear.
Old 05-25-2009, 07:12 AM   #4
All of the above. If left unfinished, PT lumber will crack and check badly in a short time. It won't rot, it will just look bad. Consumers rates deck finishes fairly often, but they usually rate the solid stains as the best, because they cover up the wood. Some people like to see the wood grain, so clear or semitransparent finishes is what is needed there. They are often only good for 2-4 yrs.
Old 05-25-2009, 06:43 PM   #5
My reason for asking is that im installing a 6' frivacy fence around my back yard. Iwould like it to last as long as possible.
Old 05-26-2009, 10:07 AM   #6
Registered User
Termite's Avatar
Then don't use pressure treated material for the pickets. It'll look like crud in 3 years. Cedar is a much nicer option and will retain its good looks with proper routine application of stain/sealer.
Old 05-26-2009, 11:31 PM   #7
Thanks for the help folks! Now all I have to do is ask the wife what color I want my fence
Shoddy Pressure Treated Lumber? spanky77 Building & Construction 17 06-25-2011 09:09 AM
pressure treated lumber - Painting Question slim one Painting 1 05-05-2009 07:35 PM
which roofing nails for pressure treated lumber ? amakarevic Building & Construction 11 01-30-2009 04:26 AM
Pressure Treated Lumber for Basement? mfleming Building & Construction 5 06-18-2008 09:43 AM
Help! My pressure treated lumber is warping! jrepp Building & Construction 5 10-31-2007 04:15 PM
