Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-12-2011, 05:55 PM   #1
Preparing Outdoor Wood Porch Floor
In the past prior to painting floor I would fill any cracks or spaces in the the wood that has delvelop over the winter from expansion and contraction.
I used what I believe was an acrylic material to accomplish this and it has worked well. It was a paste and I applied it with a brush and was quick drying.
I purchased it at Lowe's but I no longer can find it there. The associates think I am dreaming when I describe it. It was in a gallon can with a blue and white label I believe.
Would anyone be familiar with this and know where I can find it? Thanks!
TFSpaniel is offline   Reply With Quote
Old 12-04-2011, 07:33 AM   #2
I've never heard of that before. Personaly I'd never fill the cracks, the reason being once the wood swells again it's going to split the wood because it have no place to expand.
But if I was filling the cracks I'd use what I think is called Burmans Water Puddy. Mix in small batches because it hardens fast. Once it hardens in a few min. it's real easy to sand and will paint over perfect.
I use it all the time when I'm trying to fill in the old hindge mortises and latch plate areas after reversing the swing on old doors. Once done you can not see where it was done.
Old 12-04-2011, 07:38 AM   #3
old guy contractor
tcleve4911's Avatar
I used to use Burman's all the time.....
until the painter turned me onto Bondo.............
tcleve4911 is offline   Reply With Quote
Old 12-04-2011, 07:40 AM   #4
Bondos fine except I keep loosing the hardner, so I use Burmans. I can always find water to mix that with. lol
tcleve4911 (12-04-2011)
Adding to Concrete Porch + Steps? 99altrade Building & Construction 8 08-01-2011 01:14 PM
Subfloor for slate tile on a screened in porch floor Scruffy Flooring 5 11-03-2010 09:26 PM
Preparing to lay a ceramic floor jrh388 General Discussion 1 09-18-2009 07:02 PM
Hardwood floor questions (56K) ukrainetz Flooring 1 08-02-2009 02:08 PM
Enclosed Porch Floor Joists detanner Building & Construction 5 01-27-2008 07:31 AM
