Preparing To Lay A Ceramic Floor - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-18-2009, 04:56 PM   #1
Preparing to lay a ceramic floor
I'm preparing to lay a ceramic tile floor on an existing concrete floor. The tutorial I'm watching says you need to install concrete backerboard before installing a ceramic tile floor. Do I need to do this if the existing floor is level concrete?
Thanks for your help.
jrh388 is offline   Reply With Quote
Old 09-18-2009, 06:02 PM   #2
Rewards Points: 1,016
No - lay directly on the concrete. You need to check the level of the concrete - really check, as in get a long straight edge (~6-8') and move it around the floor looking for low and high areas.
I recently did my kitchen and the level looking concrete had a good area with 1/4" variences in a few feet. Fixed it with leveling compound. Then the 20x20 tiles went down and look great.
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
ceramic floor Unregistered Flooring 4 03-19-2011 01:56 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 12:11 PM
Preparing sub floor for tiles Franky Tiling, ceramics, marble 15 01-21-2009 06:29 AM
drilling in ceramic floor tile mrmac204 General DIY Discussions 4 04-14-2008 09:27 PM
