Prehung Door Install Problem - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-06-2008, 03:35 PM   #1
Question
Prehung Door install problem
I just installed a brand new pre-hung fiberglass Jeld-Wen exterior door. To the best of our knowledge. everything is plumb, level and square as the door sits now. As with a similar post one small problem, the top of the door (handle side) sticks out. Bottom is ok. Hinge side, jam has same reveal along jack stud. Door opens and closes nicely. top of door does not seal . Is door warped? Any ideas on how to correct this? Other than getting another door to try.
bscj@innernet.net is offline   Reply With Quote
Old 04-06-2008, 03:52 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Did you check the wall that the door opening is in? The wall itself may be off-plumb.
- Build Well -
Old 04-07-2008, 08:12 PM   #3
remodeling pro
Like Atlantic suggested, most likely the wall opening is "twisted". Work both opposite corners, tweaking the jamb in on one corner and out on the other until the door closes evenly. By splitting the difference like this, you should end up with smaller gaps in the trim/jamb connnection that are easily caulkable.
troubleseeker is offline   Reply With Quote
Old 04-08-2008, 10:40 PM   #4
Rewards Points: 5,336
As previously stated, the door is racked, which means it's not plumb. Use a plumb bob to verify. Levels can deceive.
Ron
Prehung entry door gap problem 1fstws6 Building & Construction 3 03-21-2008 07:45 PM
GMP100-3 Problem hansim4 HVAC 2 12-13-2007 03:55 PM
Phone Jack Hookup Problem kennykenny Electrical 18 12-07-2007 03:48 PM
1994 camry rear suspension/tires problem marks5894 Automotive Repairs 2 11-05-2007 05:12 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
