Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 08-29-2012, 07:30 PM   #1
precision axial cutting of thin-walled brass tube
I have some thin-walled (0.015") brass tube and am wondering how to cut it axially, without bending it or creating lots of burrs, to end up with something that looks like the picture below.
diy888 is offline   Reply With Quote
Old 08-29-2012, 07:48 PM   #2
How about a jig on the table saw? The jig would gently sandwich the sides and really hold it on the ends.
How long of pieces are we talkin?
mae-ling is offline   Reply With Quote
Old 08-29-2012, 08:19 PM   #3
The length is going to be 12mm (1/2").
Old 08-29-2012, 09:45 PM   #4
band saw
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 08-29-2012, 10:26 PM   #5
A slitting saw is how they would do it on a commercial level.
What is it your going to be doing with it?
Old 08-29-2012, 10:34 PM   #6
JOATMON
ddawg16's Avatar
Originally Posted by Fix'n it View Post
band saw
x2
Make a jig that will hold it perfectly vertical.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 08-30-2012, 01:26 AM   #7
Lavid2002's Avatar
How many do you have to make? I'd just put it in a vice and slice it with an angle grinder.
Lavid2002 is offline   Reply With Quote
Old 08-30-2012, 07:09 AM   #8
.015 is pretty thin and doing it without bending it is a problem.
I might try a jig on a bandsaw, depending on the diameter and length.
How precise does the slit need to be?
I might have a sample water jetted and see how it comes out.
How many and how precise are going to help decide how it gets done.
7echo is offline   Reply With Quote
Old 08-30-2012, 07:25 AM   #9
sdsester's Avatar
Might stabilize it with a dowel down the center.
Water jet or laser cutting it would be possibilities if you send it out.
sdsester is online now   Reply With Quote
The Following User Says Thank You to sdsester For This Useful Post:
drtbk4ever (08-30-2012)
Old 08-30-2012, 02:58 PM   #10
I am using it as a sleeve tensioner between some shafting and a v-belt idler pulley whose bore is a smidgen too large for the shaft.
I've managed to cut a section with a tube cutter and then axially with a small hack saw but it did bend, the cut is not straight and clean, and I'm going to have to try to clean it up with a file. It works as intended, sort of, though the dent creates some clearance issues--have to really force the idler pulley onto it.
Old 08-30-2012, 02:59 PM   #11
Thanks for the dowel suggestion.
Old 08-30-2012, 03:00 PM   #12
Only about a dozen or so. Angle grinder seems sort of unwieldy (at least in my hands).
Old 08-30-2012, 03:03 PM   #13
Is there a kind of jig saw blade that wouldn't wander around the face of the tube but would bite right in? Something really fine and made for metal?
Old 08-30-2012, 04:20 PM   #14
At .015" thickness, I would at least take a shot at a simple jig, basically a dowel with a stop to slip the sleeves over, clamped such that I had a guide parallel to the dowel, and try slicing it with a utility knife.
Old 08-30-2012, 05:50 PM   #15
Dowel is Genius idea!
Don't think a band saw will work as he wants a slit not 2 pieces.
