Power Outage - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-23-2011, 08:23 AM   #1
power outage
I woke up this morning to find one corner of my house dark. Inside and outside lights out.
I checked the breaker system to find NONE had popped....I looked at the power surge I have plugged in...nothing...but when I looked outside, my outlet that is there is soaked...its not a protected outlet as my house very very rarely gets water in that area...could that be a cause for the outage? if so...how do i resolve this quickly.
BAILEYANNE is offline   Reply With Quote
Old 11-23-2011, 08:39 AM   #2
joed's Avatar
Rewards Points: 12,924
Look for a GFCI in the garage, basement or a bathroom that controls all the affected devices.
Are they all on the same circuit?
Old 11-23-2011, 08:41 AM   #3
yes they are all on the same circuit....the outside plug is suppose to have a red "reset" switch but its not working...and there is water inside the outlet.
Old 11-23-2011, 09:02 AM   #4
Rewards Points: 5,336
You need to change the outlet. You also need to find out why there was water inside the box and fix the issue before the next outlet goes in.
You need to find the breaker the outlet is on and shut it off before repairs are made.
Ron
B. Franklin 1759
Old 11-23-2011, 09:04 AM   #5
Military Mom of 4
Snav's Avatar
You MUST test the outlet and wiring before you work on it - it's possible that your breaker isn't working properly - be safe, don't get shocked over a plug!
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 11-23-2011, 09:11 AM   #6
the reason why there is water is because that outside outlet is not protected and it rained horribly here....I am wondering if its a NFG outlet...I am going to try drying the outlet first and reseting it...if that works I am going to try switching the outlet with one that is protected so water doesnt get back in.
Old 11-23-2011, 10:14 AM   #7
All exterior outlets need to be protected with an approved exterior cover.
Having an exposed outlet outside is dangerous.
I have no idea what NFG means, but once it's wet, it's garbage.
Ron
B. Franklin 1759
Old 11-23-2011, 11:38 AM   #8
Rewards Points: 106
Correct. You dry clothes and other items, but drying electrical devices, rather than correcting the situation and replacing the device, is one of several first steps toward eligibility for a Darwin Award.
Your local hardware store or big box will have packages on the shelf, which will contain a GFCI and weather tight box. Follow the instructions carefully, but if you find yourself in unfamiliar territory, I suggest calling a local electrician.
Old 11-23-2011, 11:53 AM   #9
Curiously enough, the award is always given out postumously.
Ron
B. Franklin 1759
Old 11-23-2011, 12:07 PM   #10
Rewards Points: 106
Yes, I believe that is correct. I wonder how many start with "here, hold my beer" and "watch this", as compared to "aw heck, this will work for now".
Old 11-23-2011, 01:13 PM   #11
Hell of a fella
Rewards Points: 27
just put 2 of those outdoor receptacles in at my house...very nice for the price. found a whole kit at lowes for about $10 i believe. they come with box, outlet, gasket, and sealant
DrumBum is offline   Reply With Quote
Old 11-28-2011, 08:27 PM   #12
Rewards Points: 115
if NFG outlet means what I think it means if it got wet it truly is one. replace it and make sure you use a weather proof box. find out why it got wet in the first place. be sure to turn breaker off
pokey is offline   Reply With Quote
Old 11-28-2011, 09:50 PM   #13
Power Outage Issue? rbjones6 Electrical 13 05-24-2011 12:59 AM
Power Save Device capt2 Electrical 52 02-24-2010 06:42 PM
house power supply upgrade in Australia pcd1965 Electrical 3 08-22-2009 08:17 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
