Power Inverter For Air Mattress - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-20-2013, 12:00 PM   #1
Rewards Points: 32
Power Inverter for air mattress
I have an aerobed that I take camping but last year we ran into a problem. The power inverter I had wasn't strong enough to power up the mattress. We ended up having to blow it up elsewhere.
The air mattress manual says: Plug into any polarized 120 VAC electrical outlet. North American Electrical rating: 120 VAC 60HZ 1.6 A
The inverter I had: DC to AC 300 Watts Peak 150 Watts Continuous
I just read on the back is says Output: 115 VAC 150W
So basically what I need is to find an output of 120 VAC?
beh162 is offline   Reply With Quote
Old 04-20-2013, 12:10 PM   #2
jproffer's Avatar
Rewards Points: 702
I'd say you need to find an output of more like 200 Watts...the 115V vs. 120V is a non-issue.
1.6A x 120V = 192 Watts
jproffer is offline   Reply With Quote
Old 04-20-2013, 12:20 PM   #3
Rewards Points: 32
Oh I see...
So far I've only found outputs of less than 120V. Do I need to worry about the watts when I'm looking?
Old 04-20-2013, 12:22 PM   #4
Rewards Points: 32
I mis read what you were saying! Ohh Okay now I know what I have to look for!
Old 04-20-2013, 12:25 PM   #5
Too Short? Cut it Again!
Don't they sell DC air pumps for those things you can run off the vehicle electric to inflate them?
Old 04-20-2013, 12:29 PM   #6
Rewards Points: 32
This has a pump built in with a plug attached. So unfortunately, I can't buy a DC pump to attach.
I see this on for $39
300 Watts Continuous, 600 Watts Peak Power
Converts 12 Volt DC to 115V AC
Output power (peak) = 600W
Output power (continuous) = 300W
Input voltage shutdown = Yes 11-15V DC
Output voltage = 115V AC, 60Hz
Old 04-20-2013, 12:34 PM   #7
jproffer's Avatar
Rewards Points: 702
According to the matress info above and the inverter info there, that one should work for what you're doing.
The Following User Says Thank You to jproffer For This Useful Post:
beh162 (04-24-2013)
Old 04-21-2013, 09:58 AM   #8
Bill Kearney
Rewards Points: 1,174
The problem with low-end inverters is they don't have enough power to support the startup current of some devices. They might list having enough but still fail to get the devices going. I ran into this trying to power up an AC-only TV/DVD in our boat. I had to step up to the next level of inverter to make it work.
wkearney99 is offline   Reply With Quote
Old 04-21-2013, 10:12 AM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 850
Ok.....I see a big problem here......Camping?....air mattress? That's not camping.....that's just a cheap version of a motel 6.
Now that I've had my fun.....when I go camping with the boys....they are on roll up pads.....I like my comfort. My one mattress with the built in pump also has batteries.....have you checked yours to make sure it does not also have batteries? I also have a battery powered pump....not to mention a hand pump that I like for the kids to use....helps get rid of some of the energy they have.
Instead of an inverter, just go with a battery powered pump. It will be cheaper than the inverter...
Old 04-21-2013, 10:31 AM   #10
Bill Kearney
I don't think the indoor aerobed models have either a fill valve nor a separate DC input. They're AC only and not really intended for anything other than indoor use when you've got reliable AC power. For outdoor they sell models that use a DC supply.
You'll just need to get a better and larger inverter. Bear in mind, the current needed to inflate that thing will drain quite a lot from your batteries. Do no expect to do this at least without the engine running. And your vehicle better have enough spare amperage to support running the inverter. A small car with a tiny alternator might not be capable of keeping the battery charged while the pump is running. You'd end up depleting your battery even with the engine running.
Old 04-24-2013, 08:55 AM   #11
Rewards Points: 32
It's called 5 star camping... not that I was asking us to trade camping setups.
The inverter is due to come on Friday so I'll have to check it. It's a Tahoe truck and it will be turned on while we do the air mattress'
If I need to upgrade to a higher end... how much higher do I look at? 1000W?
Old 04-24-2013, 09:03 AM   #12
Bill Kearney
Call the bed makers and ask if they've dealt with this question before.
Old 04-24-2013, 06:02 PM   #13
Special User
Rewards Points: 1,230
Motors typically draw 2X to 3X the current on startup... so a 192 watt motor might pull 400-600 watts when it first starts up.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Dishwasher Power Supply Captain.Sassy Electrical 14 09-14-2011 06:28 AM
Dumb electrical question about potentially overloading a power socket zapp Electrical 2 02-18-2011 10:43 AM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 07:15 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
