So we have plans to renovate the downstairs in our split and I just assumed that there were lally columns so we had the plans done for an open concept. Now I'm not so sure. The walls are thicker than usual but I figured they did that to accommodate the columns but the four holes I punched I couldn't see any and it got me thinking that maybe the center wall is load-bearing and there are no columns. Could this be the case, could this wall hold up the entire upstairs?
So which wall are you talking about? And how much "thicker than usual" is it? If just a bit, it could be a plumbing wall framed with 2x6s instead of 2x4s. My log house has only one interior load-bearing wall, and it is the same thickness as all the rest. Same for other houses I have owned.
Just thought of something...Is this a modular? What is in the basement directly under this wall? got any general shots of the outside of the house you could post that show the end wall? How about the inside where this wall is
I'm guessing whoever did your plans did not determine if this was a load bearing wall? I'd get them back out there if it were me.
is there a beam under that wall in the basement with lally columns? do the ceiling joists/2nd floor joists terminate over that wall? if so then it's load bearing.
it is uncommon in my experience in Massachusetts that a beam with columns would be installed to support loads above and then build a partition wall to fill in below the beam. Of course I have found those conditions in post-and-beam homes, but as I said it has not been a common occurance on my part.
If this is a one story with truss I would think yes it's load bearing.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
