Possible Septic Issue? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-17-2011, 06:39 PM   #1
Hello All! I am new to this and seek help. My wife and I are looking to pretty up our landscape and make it more usable. We are planning a small patio. We need to level off out property but before that I need to find the lid to my septic tank. I'm planning on putting some type of manhole cover access to it. While going over my property I found a spot on my property (approx. 3ft. in diameter and over what may be the lid to the septic tank.) that sinks much more than any other part when you walk over it. Not only does it sink but sprinks back almost like a trampoline. It is roundish in shape and grass doesn't seem to grow on it (haven't tried all that hard).
Has anyone ever encountered this? What causes this? How do I fix it? Any help would be very appreciated.
Thanks a million.
bigheadnred is offline   Reply With Quote
Old 07-17-2011, 06:45 PM   #2
Rewards Points: 6,652
Either use a shovel and start digging, or get a 4 foot to 5 foot piece of 1/2" rebar and start probing for the lid. You will know when you hit it. As for placing a patio or deck over it, unless the patio can be torn up easily, I would not place anything over the Septic tank.
Old 07-17-2011, 06:51 PM   #3
Thanks for the quick response but do you know what is causing the springing effect in that one particular spot on my lawn?
Old 07-17-2011, 06:53 PM   #4
You will have to grab a shovel and play archaeologist to find out. Just go slow & easy, do not rush, or you may have bigger issues. Do you know how old this septic system is, and the last time it was cleaned out?
Old 07-17-2011, 06:58 PM   #5
10 years old and never pumped
Old 07-17-2011, 07:14 PM   #6
Then it is time to have it done, before doing any landscaping. Hopefully the field has not failed, along with the tank.
Old 07-17-2011, 07:24 PM   #7
No Plumbing issues or strange smells (thank GOD!!!) so im a bit confused.
Old 07-17-2011, 07:33 PM   #8
If it has been ten years, not being pumped, and not knowing when it was last inspected, it is time to do so. Septic systems can fail, even though inside you do not have any issues with the plumbing.
Old 07-17-2011, 08:01 PM   #9
FlyingHammer
If the tank is only 10 years old, check with your county building department. They should have records showing exactly where the tank is located.
And I agree you need to get it pumped asap. Here in WI they won't let you go more than 3 years.
FlyingHammer is offline   Reply With Quote
Septic problem or vent problem? wilsonstark Plumbing 9 01-17-2011 06:35 PM
septic tank issue..options? jaycenter Plumbing 4 07-02-2010 08:05 PM
septic vent issue utilitylocator Plumbing 1 03-15-2010 01:14 PM
septic tank problems. littles Plumbing 1 02-24-2010 09:30 PM
septic issue? musty smell in house, and toilet won't flush karen71 Plumbing 5 02-18-2010 03:14 PM
