Is It Possible To Cut 1/2" Plywood Without Shredding It? - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-01-2013, 10:06 PM   #16
Davejss's Avatar
Rewards Points: 740
First of all I would use a decent corded saw. Most cordless saws don't have enough power. Second, use a straight edge and score the plywood on both sides with a utility knife. Third, buy a very good quality carbide finish blade.
Davejss is offline   Reply With Quote
Old 06-01-2013, 11:21 PM   #17
Roofmaster
Rewards Points: 2,172
Its hard to tell from that picture but it looks like you are cutting perpendicular to the grain, and it looks like the surface veneer is luan. You are probably using a 24 tooth carbide blade also.
1. Change to a plywood blade.
2. Put the finished side down when you cut. A circular saw cuts up through the material.
3. As Willie said, you score the surface where the blade comes up through with a razor knife and cut just to the right of the score line.
My dad taught me that one way back when when we had to trim doors down for the nut cases that put wall to wall carpet over their hardwood floors. Back when WTW was all the rage. It was a sales BS routine adopted by builders to get out of putting down hardwood.
Kind of like the rage about Stainless Steel Appliances, and granite is now. As my grandson says
"Granpa, why do they call it Stainless, when all it does is show Stains, like fingerprints? Why dont they call it stain-full Steel?
Kids a pisser. A correct pisser.
PS I did not know you were using a battery saw. A good corded saw is much better, as the others said. 7-1/4 inch Makita is good. High speed steel plywood blades for finish work. Notice I said blades, as in plural, as they don't last long.
The Following User Says Thank You to jagans For This Useful Post:
RWolff (06-04-2013)
Old 06-03-2013, 06:14 PM   #18
custom user
Rewards Points: 150
A good sharp carbide blade made for crosscutting and an a/c powered saw will do it. It will have many teeth, at that size I believe around 40. If you want to get real fancy a triple grind blade (if they make them that size) will do wonders.
JasperST is offline   Reply With Quote
Old 06-04-2013, 12:02 PM   #19
One option not mentioned is to perform a rough cut with a saw, then the finish edge with a router and straight edge. I have had good luck with this approach.
oberkc is offline   Reply With Quote
Old 06-04-2013, 12:28 PM   #20
Rewards Points: 626
Yep do it all the time. use my table saw with a deablo blade for plywood turn the finish side down and vola perfect cuts every time.
Nailbags is offline   Reply With Quote
Old 06-04-2013, 01:18 PM   #21
Old School
Willie T's Avatar
You also might find that making a few jigs like this will be of benefit.
I have an 8' one, a 4' one, and a 2' one. Mine are a little different in that I set up BOTH sides on mine... one side for a skill saw, and the other side for a router.
Willie T
Old 06-04-2013, 01:47 PM   #22
Roofmaster
Finish side Up with a table saw, Down with a circular saw. I think you were confused. Dont worry, it gets worse.
Willie T (06-04-2013)
Old 06-04-2013, 02:37 PM   #23
Rewards Points: 578
Doesnt work if you need both sides finished. Doesnt matter anyway, i was planning to use it to make my doors and that isnt going to work. So, sorry to waste your time.
Come and see the progress on my mobile home paradise!!! (NEW PICS ADDED ON 01/26/15!!)
http://www.diychatroom.com/f49/compl...emodel-168570/
TrailerParadise is offline   Reply With Quote
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 03:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 06:08 PM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-14-2010 12:09 AM
Plywood thickness: asked for 1/2" plywood; hardware delivered 7/16 (.437) thickness) lazzlazz Flooring 7 03-31-2010 12:25 PM
3/4" T&G plywood over 1/2" subfloor Stude Building & Construction 14 12-26-2009 03:38 AM
