Possible Buried Oil Tank? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-04-2010, 10:56 PM   #1
Question
Possible buried oil tank?
I was wondering if anyone knew what the attached picture is? It is buried in the ground directly behind a house built in 1955 in Florida. I think it might be the lid of an old oil tank or septic cover, but am not sure. Any ideas?
Thanks,
Lawrence
Law Richardson is offline   Reply With Quote
Old 12-05-2010, 12:55 AM   #2
Rewards Points: 1,092
could be near anything. pop the cap and let us know; don't breathe it. j
The Following 2 Users Say Thank You to jklingel For This Useful Post:
Law Richardson (12-06-2010), oh'mike (12-05-2010)
Old 12-05-2010, 06:49 AM   #3
I would say not an oil tank, could be a water meter, not likely a septic tank.
The Following User Says Thank You to Just Bill For This Useful Post:
Old 12-05-2010, 08:38 AM   #4
This sounds stupid because why would a 1955 house have one, but it looks like a grease trap that I deal with at my employers here in upstate NY. I wouldn't think a house would have one but anything is possible. Crack the lid and send a picture of what you find. Be careful, loosen nuts slowly. If there is any pressure in the vessel you may get water or other nastiness backflowing.
sbfan2000 is offline   Reply With Quote
The Following User Says Thank You to sbfan2000 For This Useful Post:
Old 12-05-2010, 08:50 AM   #5
the Musigician
DangerMouse's Avatar
If you have 'city water' it COULD be the outside shut-off.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
Old 12-05-2010, 09:03 AM   #6
Household Handyman
Rewards Points: 1,408
Note that the two "bolts" appear to be recessed into a counterbored space. This appears to be intentional so that you would need a special socket or "key" made to fit down into that area. Something that a homeowner would not readily have. Maybe a public utility or even a fuel oil supplier. But-if it were for fuel oil there would have to been a vent piping also. The white cap on the right I hope is for reference as to the size of this unit. I would contact the local building code authority and see if anyone is there that may know something about codes back in 1955 for fuel oil tanks, or even (as stated) the septic system, if so equipped. Those bolts are there for a reason. Either a pressure situation, or a "tamper-proof" situation. Just my nickel's worth there, David
The Following User Says Thank You to Thurman For This Useful Post:
Old 12-05-2010, 09:06 AM   #7
Rewards Points: 5,336
Looks like a water shutoff box.
Ron
The Following 2 Users Say Thank You to Ron6519 For This Useful Post:
DangerMouse (12-05-2010), Law Richardson (12-06-2010)
Old 12-05-2010, 09:28 AM   #8
the Musigician
I'm pretty sure it IS a water shutoff. We had one at our old home that pretty much looked like that.
They open the lid, then use a long steel rod/tool to turn on/off the home's water supply.
DM
Old 12-05-2010, 09:33 AM   #9
kwikfishron's Avatar
Rewards Points: 822
The thing to the right looks like painted over meter.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 12-05-2010, 03:22 PM   #10
I'm not sure the size of this thing, the weeds make it look bigger than a water shutout riser but the cap makes it look to small to be a grease trap, it's definitely to big to be the fill on a oil tank, unless it's a HUGE tank. After looking further at it I would lean towards water shutoff but there is one other thing about that idea.
I work with water shut off risers all the time, I have the water keys that remove the nuts and the wrenchs that reach down in there to turn the valve off. I deal with valves from 2" up to 12" and this riser is not something I've seen. From what I've been told water risers have to say "Water" on the top of them just like sewer man hole covers have to say "Sewer" on them. Does that mean they all do? Of course not, but most that I've seen do say water on them.
Maybe it's the clean out for the waste water leaving the house?? Being that it's in back of the house also makes me question water shut off idea. Those are 1. usually out close to street and 2. at the front of the house. However, waste water ussually leaves the back of the house to go to the tanks/leech field, that is if you don't have city sewer. But remember that in 1955 it was very likely to have your own leech field. Of course, all my experience has been from Ohio and north. Florida is way different. :-)
Old 12-05-2010, 03:29 PM   #11
almost looks like the top of a well
Everything I state on this forum is an opinion I have developed based on my experience and research as a professional.
wnabcptrNH is offline   Reply With Quote
The Following User Says Thank You to wnabcptrNH For This Useful Post:
Old 12-05-2010, 09:34 PM   #12
Rewards Points: 33
Opening it to see what's inside sounds like the logical approach. You could however, measure where it is in relation to the inside of your home. Possibly from one of the building corners to see if a pipe penetrates the foundation wall in a basement or up into a crawlspace.
Any of the guesses made could be right. Is, or was there ever a pool, spa, or lawn sprinkler system in the backyard? Wondering if it's some kind of shut-off for either.
Bob Deb is offline   Reply With Quote
The Following User Says Thank You to Bob Deb For This Useful Post:
Old 12-05-2010, 09:52 PM   #13
A Little Of Everything
Rewards Points: 1,364
I'd say it's the cap of either a cistern or a septic tank. More likely the latter.
DrHicks is offline   Reply With Quote
The Following User Says Thank You to DrHicks For This Useful Post:
Old 12-06-2010, 01:02 AM   #14
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
So have you figured it out yet?
Inquiring minds want to know.
If you haven't figured it out yet I would take a wire brush to it to see if there are any markings underneath all that rust.
Or take a pic (with measurements) to your local building inspector or permit office.
The Following User Says Thank You to Blondesense For This Useful Post:
Old 12-06-2010, 07:59 AM   #15
Thanks, for all your ideas. I have not opened it yet but here is more information. The house is on septic and a private well. The well pump is 20 feet to the right of this. The septic tank is 20 feet north of this around the left side. This buried tank is directly behind the bathroom ( near bath tub and toilet). Thanks.
Tags
buried , exterior , inspection , oil tank , septic
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Propane Tank buried vs. above ground CheriAlli HVAC 17 11-17-2010 11:05 AM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 11:09 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
