Possible To Build This Fence From Wood? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 11:22 AM   #1
Possible to build this fence from wood?
Do you think itís possible to build the pictured fence from wood and for it to be durable? I assume the pictured fence is iron but from the picture I canít be 100% sure. I would want to keep the light open look so I wouldnít want to use 2x4ís for stringers. In the picture, the stringers appear to be about the same dimensions as the vertical pickets. If the pickets were glued to the stringers would each section be ridged enough to keep it from sagging over time? I would appreciate any insight, comments or recommendations.
Mike in Arkansas is offline   Reply With Quote
Old 11-15-2011, 11:53 AM   #2
jschaben
Rewards Points: 502
Hi Mike - pretty long span but I think it would be doable. I said doable, not easily doable. Looks to me like the pickets and stringers are 2x2's. Probably a 14 or 15 foot span. If I were gonna do it they would all be half-laps.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 11-15-2011, 12:33 PM   #3
Old School
Willie T's Avatar
Yeah, half-laps. But that would be a lot of work, and the probability is that you would still have terrible sagging.
FranÁois Duc de La Rochefoucauld
Willie T
Old 11-15-2011, 12:39 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Divide the span by three and install two more legs in the ground on each span. They would only show below the bottom rail.
Old 11-15-2011, 01:08 PM   #5
Military Mom of 4
Snav's Avatar
There's no sense of depth - I can't guess the length of spans. could be 8', could be 12' . . . and those are obviously pre-fab seeing as how they run into the ground for lack of slope.
but make it yourself? Sure - anything's possible - might not be traditional construction methods but the choice of wood and other materials would be key to pulling it off.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 11-15-2011, 01:13 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I'm guessin' sixteen foot spans based on the size of the posts used which I'm thinking are about six inches.
Old 11-15-2011, 01:15 PM   #7
Msradell's Avatar
Rewards Points: 348
You can actually make all of it but the bottom rail out of wood and make the bottom rail of square tubular aluminum. That would prevent the sag and still be lightweight. This idea would work especially well if you had a wide gate. The aluminum is easily available and not terribly expensive.
Msradell is offline   Reply With Quote
Old 11-15-2011, 01:37 PM   #8
Sagging would be my concern, also. I would consider cables between the top of each post and the center bottom of each span (like a suspension bridge). It would be my hope that the cables could be small enough that they would be unobtusive.
oberkc is offline   Reply With Quote
Old 11-15-2011, 04:44 PM   #9
Rewards Points: 5,336
Span seems to be about 12 feet, but you can make it any distance you want. You just need to drop supports every 4 feet or so.
If you have a mortiser tool or a drill press with a mortise attachment you could drill out a 2x4 for the spindles.
A lot of work and a lot of places for water to get in and rot the wood.
Ron
B. Franklin 1759
Old 11-15-2011, 04:47 PM   #10
Military Mom of 4
Snav's Avatar
So - OP - did you finish the project yet :D
Old 11-15-2011, 06:09 PM   #11
Not done yet Thanks for all the suggestions and input. My guess is a 12 foot span also, based on a 1 1/2 inch square picket but who knows for sure. I really like the fence but at this point you all have about convinced me it's going to be too problematic to attempt. The picture is from a video capture of a tv program called Wind at My Back and is show occasionally during the closing credits but have never seen any closeups. Oh well, a standard picket fence may be my best option.
Old 11-15-2011, 06:16 PM   #12
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
2x2s tend to warp so bad, don't think this would work.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 11-15-2011, 11:08 PM   #13
Ironlight's Avatar
If you like the general concept there is a lot you could do to make it both easy to build as well as less susceptible to sagging. Make the spans eight feet, use 2x3s for the top and bottom rails, etc. If you have a router you could do the half laps pretty easily; clamp slats of the same length together and create a jig and just batch them. You could assembly line fence sections pretty efficiently.
I think it's a question of how wedded you are to that exact design.
Of course, the real problem with that fence is you have to paint it. Yuck!
Ironlight is offline   Reply With Quote
Old 11-16-2011, 06:28 AM   #14
kwikfishron's Avatar
Rewards Points: 1,018
As mentioned a couple of short post supporting the bottom rail along with the half lap would take care of the sag.
I agree with using 2x3 instead of 2x2. I’d also stay away from treated yellow pine. Cedar or even treated fir are more stable and would have less of a chance of twisting and checking.
kwikfishron is online now   Reply With Quote
Old 11-16-2011, 06:44 AM   #15
the Musigician
DangerMouse's Avatar
They look to be standard 4"x4" posts to me. 8' spans maybe?
DM
Cedar Wood Fence - Staining again ddave23 Painting 13 03-22-2012 05:43 AM
Wood Fence to vinyl siding Tgordon Building & Construction 1 11-01-2011 04:52 PM
How about to build a wood path? dianachen Building & Construction 10 11-20-2009 01:24 PM
DIY Replacement of a Wood Fence rcraftlady Building & Construction 4 03-11-2009 06:03 PM
Preferred Fence Wood? Medium_Pimpin' Building & Construction 2 07-06-2007 09:21 AM
