Portable Air Conditioner On Hardwood Floor - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-19-2012, 04:56 PM   #1
Rewards Points: 190
Portable air conditioner on hardwood floor
I refinished my hardwood floors when I moved in. Purchased a portable air conditioner on wheels and put it in the dining room. Came home one day and there was a puddle on the floor. Uses shop vac. There was so much water it went into my basement. Here I found out a plug was never installed on it. Looked today because the company sent me a plug and the floor is warped about 12 inches by 4 feet
ryanb4614 is offline   Reply With Quote
Old 06-19-2012, 05:12 PM   #2
Rewards Points: 13,274
Post a picture.
May have to cut out that section and replace it.
I've never once seen a lifted hardwood floor go back into place once it drys out, but I have seen black mold growing under the floor from trapped moisture.
Old 06-20-2012, 11:21 AM   #3
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Yes - we need a picture.
There was water damage in a corner of my wood floors when I pulled the carpets up, probably from an old a/c. I didn't have much "up/down warping" though and we were able to smooth it out by sanding about 1/4" off it w/ a drum sander.
CoconutPete is offline   Reply With Quote
Old 06-21-2012, 08:26 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Hardwood floors can (in some instances), in fact, return back to their shape and place - after experiencing moisture. As stated above, sanding and refinishing can then be performed.
Example: http://www.woodfloorsonline.com/tech...od_floors.html
- Build Well -
Old 06-21-2012, 05:18 PM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Originally Posted by joecaption View Post
Post a picture.
ahh, never mind
Old 06-21-2012, 07:23 PM   #6
Rewards Points: 1,062
Right, but they will always retain the water STAIN.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 06-22-2012, 02:16 PM   #7
Rewards Points: 504
If the damage was bad enough - yes. In some cases you can get them out - I did, but like i said - we probably sanded 1/4" off the entire floor. In reality maybe it was more like 1/8" but it FELT like 1/4"
Old 06-23-2012, 11:21 AM   #8
AHH, SPANS!!!
Rewards Points: 1,166
consider a dehumidifier in the room for a while to help contain any moisture and encourage drying of the wet area. If no dehumidifier then just a regular fan blowing into the room will help. give it time to dry out some and that will allow you to be able to see what it does over time. also, consider putting a fan in the basement blowing up toward the underside of the floor where the water drained.
hand drive is offline   Reply With Quote
Old 06-27-2012, 03:40 AM   #9
Mold is something to watch out for it can grow in about 48 hours. If before you cut the section out try this:
1. Lay wet towel over the warped floor and place weight on it for 24 hours.
2. Choose a drill bit slightly narrower than your floor screws.
3. Drill holes every 3 inches through the warped floorboard into the floor joists.
4. Line up long screws with the pilot holes and sink them through the warped wood into the floor joists.
5. Fill the holes left by the screw heads with a matching color wood putty. Let the wood putty dry.
6. Sand the top of the wood putty with 220-grit sandpaper.
7. Buy a matching gel stain or liquid scratch cover to paint on over the repairs.
8. After the stain or scratch cover is dry, apply a coat of wax to the hardwood floor.
This is very close to what I've done before, but without seeing a picture it's hard to say if this would work for you.
walthill is offline   Reply With Quote
Old 06-27-2012, 11:07 AM   #10
Rewards Points: 1,442
Is your portable ac a power hog? I had one that would use more power than my central ac. It never reached the set temp so would just run all night. This was at 78 degrees in a medium sized room. I always think they're all power hogs since that experience. It cost $400 and I just gave it away.
mikegp is offline   Reply With Quote
The Following User Says Thank You to mikegp For This Useful Post:
hamada 77 (06-27-2012)
Threshhold problem with new hardwood floor. joyceg Flooring 15 01-14-2012 05:00 PM
hardwood on engineered floor? kalpi Flooring 1 09-27-2011 07:32 PM
Hardwood floor is buckling again Kerm Flooring 1 05-07-2010 06:35 PM
unique problem with hardwood floor seanbellay Flooring 15 05-02-2010 07:53 PM
Hardwood floor questions (56K) ukrainetz Flooring 1 08-02-2009 02:08 PM
