Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 07-22-2009, 08:48 PM   #1
porch roof collum repair...
I have a small entrance roof which is held up ,in part, by wooden collums. Attached to the collums are posts and rails that attach to ground post.
One of the Roof posts has wet rot on the bottom. I've cleaned out the rot and applied a wood hardener and was going to repace the dameged portion with pressure treated wood and filler, but got to thinking that the better way to do this repair would be to cut out a piece of the collum and replace it adding a piece of pressure treated wood that would fill the entire cut out. My question is how to hold up the collum and the ajoining rails while I cut and put in the replacement piece? Can I simply use wood to brace it under the railings, both on the uper landing and under the stair railings or do I need to hold up the roof directly using a 2x4, etc.
thx
________________
club penguin
hankjmatt is offline   Reply With Quote
Old 07-22-2009, 09:07 PM   #2
Household Handyman
hankjmatt-I'm sure you would agree that a picture would be very helpful in this matter, but without one- -I'm a little confused as to bracing "under the railings, both on the upper landing and under the stair railings"? Is this a two story home with stairs leading to an upper floor? Even if it is, Yes you can brace the entrance roof so that you can repair the column(s) as necessary. BUT, I would not use just one 2 x 4 board to do so. Maybe two 2 x 4's nailed together and wedged in, one on each side of the existing column, even if it is a corner column. I have removed the complete columns for repair by proper bracing of the roof while the column is out. As far as using PT wood for the repair, that is up to you, I don't because PT wood around here shrinks a lot after a short time in this heat. Using a select grade of wood, good installation, along with proper priming and painting, and this repair will be hardly noticeable, and last a very long time. Please post a picture if you can and you will receive better advice I'm sure. Good Luck, David
Old 07-22-2009, 09:41 PM   #3
Hi
David
Thanks for your reply.
I will try it as you say.
More On This Topic
This is Charles McMahon for Expert Village. Now we’ve got this chair all epoxied and clamped, we will wait for a few hours before we take the clamps off. What we should do after that and with this chair here that we have already repaired, you can... Read More »
Repair corroded lines and in your car air conditioner when repairing the accumulator; learn how in this free DIY auto-mechanic video from our expert in automotive AC repair and maintenance. Read More »
Patching a flat roof may not seem like much fun and you may be tempted to call in the experts. There are several roofing companies that only do flat roofs because of the lower amount of work involved. But you can patch your own membrane roof if you have... Read More »
The outside roof pitch on your home can be made more attractive by increasing the pitch of the roof. Increasing the roof pitch also provides a more efficient way for rain and snow to drain more easily off of the roof. Read on to learn more. Read More »
No John isn't here. These are a lot of stairs. No Red Bull. Oh a Sunny D. Alright. Oh yeah, more Sunny D. Okay. Got to stop. Remember what.... How dare you take my Red Bull. It was Sunny D. Read More »
Where porch roof meets wood siding Trish99 Roofing 14 07-16-2009 09:31 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
