Hello to all, I'm a new kid on the block, be patient with me.Keyboard is not my thing, so typo is.Great site with a lot of good stuff to the every DIY, especially me. I need help with my front porch end railings. " Fallow the slop on the floor? or level with the front railings? 1" 3/4 on 6'. I have all different opinions from locals. For me level looks normal if you looking from outside in, but weird: when it is from inside of it. Thanks!:wallbash:
Thanks robertcdf, I hope you understand my question, some times I write with my accent, as my wife say, so get little frustrating to others. I was referring to the two ENDS railing 6' feet section each.If i do as you say, the bottom railing will be 3" 1/2" above floor next the the house wall and the front post. Will be a tough job to cut the balusters. angle and different length on each one. Thanks!
Well,Selema--I see you are finding your way around!
A simple way to see what looks right for your house is to 'build' the railings with masking tape first.
I like to make the porch rails level with the top and bottom parallel to each other---try that with tape and see if you like the look-----if you don't mind the floor gap tapering under the bottom rail--then you have a plan.
If it bothers you---move the tape and look at it again----
It might take extra work but the angle should stay the same, the only that changes is the length. A miter saw makes quick work of it and it gives you the best look.
Click on 'user CP' (control panel)--upper left side of this page---box will open on left side of the page.
Edit profile---add what you need to---Mike--
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
