Porch Over Basement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-01-2015, 08:42 PM   #1
Porch over basement
New to forum. I want to redo my porch. I know absolutely nothing about construction. My father will be doing this project with me. To the topic. I own a double block with a covered porch that extends over two small coal rooms in the basement. The current construction appears to be plywood over joists covered in carpet. My wife and I want to put composite tongue and groove as our porch flooring. We want to know what would the proper process be. Do we support the roof and tear down the railing and supports and remove the porch decking. Then can we lay new plywood, some type of barrier, then the composite on top and have new railings and supports installed. I am not familiar with these kind of jobs and want to know some opinions or ideas. Any help is greatly appreciated. Thank you.
C4d2x0x is offline   Reply With Quote
Old 09-01-2015, 09:26 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,044
Pictures are your friend here.
Old 09-01-2015, 09:53 PM   #3
DIY staff
Rewards Points: 7,174
Because your house has a feature that is not common--post a sketch and/or a picture .
I wonder how the coal room roof is waterproofed.
Old 09-01-2015, 09:55 PM   #4
Msradell's Avatar
Rewards Points: 170
As WW said pictures would be very helpful. However by your description I really don't see a need for the plywood, that would just deteriorate over time. You could probably just put some type of waterproofing layer on top of the joists and then lay your tongue and groove directly on top of it. Once you need to make sure of is that there is a slight slope so the water runs off the flooring instead of staying on top of it.
Your idea about supporting the roof and starting from scratch on the flooring is definitely the best way to go.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Insulating Basement Cellar Under Porch sbkim Insulation 6 12-01-2014 01:25 PM
septic pump for basement toilet denemante Plumbing 4 02-13-2013 10:42 AM
basement under porch younghunter Building & Construction 6 02-29-2012 07:12 AM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
multiple choice - basement bathroom venting debacle and burps denemante Plumbing 1 11-15-2011 10:50 AM
