Porch Ceiling - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-15-2010, 11:26 PM   #1
hjd
Porch Ceiling
Hello all
I've got a porch ceiling that was originally covered with 3/8" plywood and trimmed with some molding along the seams. I think it was a lower grade since there were 'football' shapes that always showed through the paint. Decided to attempt to fix it and went and purchased some oak veneered plywood at the HD.
Did a nice job...tight joints, new molding that was straight as an arrow down the seams, porch is about 10' by 60'. Used heavy duty liquid nails and galvanized finishing nails to nail through the existing plywood and into the trusses that support the roof above. Got it all done, caulked and painted and started wondering. Did I select the wrong material for an exterior application? I am now concerned about lamination durability and warping. Did I make a huge mistake and if so any solutions? Thank you very much.
John
hjd is offline   Reply With Quote
Old 09-16-2010, 07:27 AM   #2
If it was stamped exterior glue on the rough side, it should be OK. Often oak, birch, etc., plywood is not exterior glue, but if it is painted, it may be OK. It is already up and finished, so I wouldn't start worrying now.
Old 09-16-2010, 08:38 AM   #3
Rewards Points: 24
The "footballs" are what the mill uses to fill knot holes, and structurally, or otherwise, there is nothing wrong with them. However, since you did not like their appearance, and do like what you have now, as Bill said, don't worry about it.
Old 09-16-2010, 10:29 AM   #4
hjd
Thank you for your responses. I suppose worrying now isn't going to do much good but it is hard not to. If it matters it was primed with Zinnser 123 and painted with 2 coats of Kelly Moore Exterior Paint. Oh and no it wasn't marked exterior. I guess time will tell. Any other comments greatly appreciated, if not I will try to put it to bed.
John
Old 09-16-2010, 01:36 PM   #5
(the original)
Rewards Points: 756
Too many unknowns here. Location (climate) would help, for one thing.
Open porch, exposed to temperature and humidity changes?
"tight joints"? Does that mean you left no room for expansion? Could be a problem down the road, especially if your area is humid.
ratherbefishin' is offline   Reply With Quote
Old 09-16-2010, 01:48 PM   #6
Rewards Points: 24
All valid points to keep in mind for subsequent projects, but since it's glued and nailed, again, don't worry about it. A good learning project.
Old 09-16-2010, 05:19 PM   #7
Registered User
Rewards Points: 4,920
The back label "exterior" is not for glue, but location: http://www.tpub.com/content/construc...s/14043_75.htm
Gary
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Popcorn Ceiling Repair CecszaR Painting 7 08-28-2009 04:37 AM
Dark color & downlighting to reduce ugly ceiling in downtown loft bathroom? fredonian Painting 3 08-17-2009 10:20 AM
ceiling not white cart Painting 7 06-22-2008 08:32 AM
