Porcelain Tile Installation Questions - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-01-2010, 07:19 PM   #1
Porcelain tile installation questions
I'm thinking about putting tile walls in one of my bathrooms. I have a few questions about it.
Can you install that stuff over a painted wall? Or would I need to remove the paint?
Also how do you install it over a power outlet or light switch? Would I have to cut the hole out and just screw the cover in over it? That's the only way I can think of to do it.
Thanks for any help
phil74501 is offline   Reply With Quote
Old 09-01-2010, 08:22 PM   #2
Rewards Points: 5,336
You can install tile over a painted surface. If it's a glossy finish, I'd lightly sand the paint to rough it up a bit.
Cut the tile the size of the box so the plate covers the edges of the cut tile.
Ron
Old 09-05-2010, 10:47 PM   #3
Ron
you will need to move the box out the thickness of the tile as well or you will not be able to screw the cover back on and the outlet will be inset.
rrambeau is offline   Reply With Quote
Old 09-06-2010, 06:47 AM   #4
I would advise to sand the paint off to create a better grip although you can put the tiles straight onto the wall.
st_browndc is offline   Reply With Quote
Old 09-06-2010, 08:27 AM   #5
There is no reason to move the box. They sell box extenders and longer screws to reach the box.
Ron
Old 09-06-2010, 12:46 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You don't "move the box"...you move the appliance. The ears of switches and outlets must be "over" the tile thereby moving them outward the thickness of the tile. Some states require "box extenders" and some don't.
Painted surfaces are known "bond-breakers" when it comes to tile but this usually isn't a major issue if the tile is being applied in a dry area other than a tub surround or shower. Scuff the paint to improve bonding and go for it.
Thinset mortar (unmodified) would be the better choice of adhesives for tiles larger than six inches. Mastic adhesives will never dry under large tiles over painted surfaces.
XXX
How to anchor toilet flange to porcelain tile? bobmg Plumbing 32 08-19-2013 10:32 PM
Bathroom Floor Tile Questions BaconK5 Flooring 2 08-19-2010 10:36 AM
Grout sealer on porcelain tile. sukhenkoi Tiling, ceramics, marble 5 04-28-2010 04:51 PM
Shower tile project (questions) fxman Remodeling 3 04-16-2008 09:39 PM
Ceramic Tile Backsplash Installation DK75 General DIY Discussions 4 11-01-2006 08:56 PM
