Popcorn Ceiling Rant... - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-29-2012, 10:43 AM   #1
A Little Of Everything
Rewards Points: 1,364
I just spent the last couple days with one of my sons & his wife, working on their house. One project was removing the popcorn texture from the living & dining room ceiling, and doing whatever necessary to repair & paint it.
This is one angle of the room(s)...
What surprised me most was the fact that the ceiling was in almost perfect condition, so I can't imagine why they even sprayed that crap on there in the first place! They weren't covering cracks or other problems.
Also, the stuff was over 1/4" thick. I don't know how many "coats" that was, and cannot imagine what they were doing.
Any idea why they would have sprayed that crap on so thick?
And who was it that EVER sprayed a ceiling down with that, stepped back, and said, "Wow, that looks REALLY nice!"???
Rant done...
DrHicks is offline   Reply With Quote
Old 02-29-2012, 11:20 AM   #2
Rewards Points: 518
That stuff is still sprayed everyday in new homes. It's fast, easy, cheap, has high hide capabilities, acoustical dampering, and looks good(matter of opinion) and lasts quite awhile before someone has to deal with it in an average of about 20 years once its collected enough dust and discolored. For some reason people feel inclined to touch it like a scab and try to do silly things like paint it and end up peeling the texture off using improper tools. Most of the time it can be left alone and does not require any freshening up.
Knock down and orange peel are nicer alternatives but require more work so most builders will only do as an extra cost where as popcorn is still default.
n0c7 is offline   Reply With Quote
Old 02-29-2012, 05:28 PM   #3
Too Short? Cut it Again!
Popcorn was a common mix of crappy ceiling paint and texture used mainly in new construction to avoid having to tape/mud or otherwise finish drywall ceilings. Some early ceilings did have asbestos but most were other materials.
It sounds like yours was a legit ceiling if it was that thick. It was probably probably sprayed on for acoustics and perhaps restoration/renovation fashion---especially if it was not covering ceiling defects. If yours was 1/4 thick it probably did have some sound dampening qualities.
No getting around that a popcorn ceiling looks like a popcorn ceiling though. Unless yours was failing, you probably could have sprayed it. Most like I mention, that were used to skimp on drywall finishing, come apart with brush and roller covers and the only possible hope is to spray them. The majority had no primer underneath them and once they start failing... At least they come down relatively easily once you commit to the task.
Best to get them down.
As a style thing, they look totally goofy and out of place as do knockdown ceilings in antique homes.
Thanks for ranting. I don't think you will find painters on this site that like popcorn ceilings?
Old 02-29-2012, 05:35 PM   #4
It sounds like yours was a legit ceiling if it was that thick and probably sprayed on for acoustics---especially if it was not covering ceiling defects. If yours was 1/4 thick it probably did have some sound dampening qualities.
No getting around that a popcorn ceiling looks like a popcorn ceiling though. Unless yours was failing, you probably could have sprayed it. Most like I mention, that were used to skimp on drywall finishing, come apart with brush and roller covers and the only possible hope is to spray them. They majority had no primer underneath them and once they start failing...
This popcorn texture was a real piece of work. It's almost as though an amateur sprayed it on. It was uneven & just kind of glopped on. I've never seen anything like it - especially the thickness. Parts of it were much thicker than other areas.
Oh well. This is a fixer-upper starter home for them - and I do mean fixer-upper. They/we have already increased the appraised value by about $50,000 since they bought it 2 years ago.
Old 02-29-2012, 07:23 PM   #5
Rewards Points: 512
its actually very easy to spray if you have the sprayer. the only real trick to it is to get it even and by the sounds of things whoever sprayed it didnt know what he was doing going over and over it to get it right and failed and gave up. ive done a few jobs but mostly just matching up after a reno/restortation.
princelake is offline   Reply With Quote
Old 02-29-2012, 08:54 PM   #6
Dr Hicks, You are a nice Dad
creeper is offline   Reply With Quote
Old 03-01-2012, 02:04 AM   #7
Rewards Points: 2,210
Were you able to take it off in big sheets with a putty knife? It is nice when you can. If it has been painted I have had to use paint scraper and scrape the entire ceiling. Not fun!!!!!!!!
mae-ling is offline   Reply With Quote
Old 03-01-2012, 07:46 AM   #8
PoleCat's Avatar
Rewards Points: 1,646
Long time ago I worked at a place that had popcorn ceilings everywhere. The boss decided we needed to patch the many blemishes that had cropped over the years and ordered a case of aerosol popcorn patch in a can. This stuff was pure comedy. The entire can would discharge explosively in about 3 seconds making a six sided mess of the room not to mention me. We ended up removing it in the end.
PoleCat is offline   Reply With Quote
Old 03-01-2012, 08:21 AM   #9
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
Hope you were careful since it could have contained asbestos.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 03-01-2012, 08:34 AM   #10
I love those popcorn ceiling repair cans.
Old 03-01-2012, 10:05 AM   #11
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Some Joe Handyman must have recommended to the PO of my house to do a popcorn ceiling in the kitchen when she had him put in a new countertop a few years ago. Nice plaster ceilings in the whole house and he covers the kitchen in that crap. I took the opportunity to scrape that crap off as well when I just redid my kitchen. I can't stand the stuff.
CoconutPete is offline   Reply With Quote
Old 03-01-2012, 10:46 AM   #12
Blues Hockey Fan
cprice12's Avatar
I hate popcorn ceilings.
I had to patch a 3-4 ft. strip along the ceiling edge in the bathroom in our old house that was flaking off over the drywall tape.
I didn't use the spray can. I used the pre-made mix.
Sucked.
cprice12 is offline   Reply With Quote
Old 03-02-2012, 06:33 PM   #13
Thank you. And believe me, there were a lot of times during their growing years, that our 3 kids thought I was anything but nice!
Old 03-02-2012, 06:43 PM   #14
You know if they tell you once a month that they hate you, you are doing a good job
Old 03-02-2012, 06:52 PM   #15
Pretty much. My wife & I decided that we weren't going to raise kids - we were going to raise adults. We didn't plan to be their best friends, but their parents. And boy oh boy, was there ever some head-knocking through the years! But, they're now all in their 20s, happily married, gainfully employed, and good & helpful people. ...and their now our friends.
Life is good!
popcorn ceiling (resurfacing) bryanp Painting 3 08-25-2011 06:16 AM
popcorn ceiling andybell Drywall & Plaster 2 09-13-2010 12:55 PM
Popcorn ceiling removal and retexturing lexter_wolf General DIY Discussions 2 05-09-2008 06:51 PM
popcorn ceiling removal and retexturing lexter_wolf Carpentry 1 05-09-2008 08:07 AM
Question about popcorn ceiling J187 Building & Construction 4 06-30-2006 02:33 PM
