Popcorn Ceiling Has Been Removed, White Powder On Sills? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-18-2007, 10:23 PM   #1
Popcorn ceiling has been removed, white powder on sills?
Hi,
We have just bought our first house, we move in in two weeks time.
The owner told us the old textured ceiling had been removed a month or so ago (house is empty owner lives in another city) new carpet was put in before this was done, the removal was done by a painter, I called the painter just to confirm how he did it all, he said he placed plastic on the floor taped it to the walls, wet the ceiling before scraping it off.
I just had a look through the window of the house today and every room that the popcorn was removed from is this white powder on the window sills, would this just be plaster or could it be part of the textured roof? Im sure I could faintly see something sparkly in the powder.
Should I be worried about this?
Darren
daz59 is offline   Reply With Quote
Old 05-18-2007, 11:04 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Hello
Welcome
Congratulations
OK...cool
OK...not so cool, It's a messy job, I'd rather do it before carpet install, but it's not a big deal really
Yeah, that's right
Well, plaster is one thing, textured ceiling another
I suspect it's dust from the texture removal or the re-taping that followed
It's unfortunate the painter didn't vacuum it up, but it is normal to see that after such a procedure
After texture removal, if often necessary re-(drywall) tape and/or add joint compound to the ceiling to smooth it out
They are often left very rough when they are to be textured, as the texture hides a lot of imperfections
With the texture removed, the rough ceiling must be patched
Sanding the patches smooth leaves a lot of dust
Nope
I suppose if the texture is from the early '70s or earlier, there is a small possibility of it containing asbestos
But I would highly doubt that an asbestos remover would leave dust behind
The whole deal with asbestos removal is to keep it wet so there is no dust
I don't see anything pointing to it being anything but normal
slickshift is offline   Reply With Quote
Old 05-18-2007, 11:17 PM   #3
Hi,
Thanks for your reply.
If it is from the texture ceiling and the ceiling contained asbestos then isn’t there a chance the powder contains asbestos?
The owner laid the carpet then decided to have the texture removed, it is a pity it wasn’t the other way around.
The owner started painting the ceiling in the master bedroom when decided to have the texture removed, I guess that wouldn’t have helped the remover. As it would have been hard to wet.
House was built in 1954 extended in 1983 two of the rooms with the texture ceilings were extended, its possible that the texture was only sprayed through the house when the extensions were done.
Asbestos was still imported into New Zealand until mid 1980’s so I guess its still possible the texture contained asbestos?
Darren
Old 05-18-2007, 11:39 PM   #4
slickshift's Avatar
Asbestos was still being used in the '80s here in the U.S. too
But not for popcorn ceilings in private homes
You'll need a local resource for info on what was used for what and when in your local area of New Zealand
Around here, it's be years too late
I've worked with asbestos before, as far as I know, you can't see it per say...not like that
If it bothers you, then have a professional service clean the place before you move in
In the meantime, I'll ask a professional asbestos sprayer if you could see in in removed popcorn dust
Old 05-18-2007, 11:46 PM   #5
I was thinking before we move in wetting all of the dust and wiping it up then hire one of those rug doctors, you know the water carpet cleaning things you hire from the super market.
I donít think cleaners could do a better job than that?
Darren
Old 05-19-2007, 06:42 PM   #6
slickshift's Avatar
Well, basically that's what he said to do if you are worried about it
He also doesn't remember being able to see it
But he says if you are worried then wet it, wipe it, dispose of it, and then forget about it
Old 05-21-2007, 01:18 AM   #7
Does joint compound or plaster have fibers in it? Had another look though the house today, there is definitely some sort of fibers on the window sills, they are about 2mm long and about as wide as hair, they look clear and can only really see them with a torch, from what I can find you are right you cant see asbestos fibers, they are 300-1200 times thinner than hair.
Also the powder from the textured ceiling, is it white or brown?
Old 05-21-2007, 04:04 PM   #8
slickshift's Avatar
Plaster can, yes
Older stuff can even have horse hair in it
J/C...if there is some with fiber, I'm not familiar with it
It's possible though
Old 05-21-2007, 05:43 PM   #9
Hi,
Here is a couple of pictures, I found some gold glitter in a couple of the lumps.
http://i178.photobucket.com/albums/w...roomsmall2.jpg
http://i178.photobucket.com/albums/w...hroomsmall.jpg
Old 05-22-2007, 03:12 PM   #10
slickshift's Avatar
Originally Posted by daz59 View Post
Here is a couple of pictures...
...ew
I'd say the white stuff is popcorn
The rest looks like cat hair
Old 05-23-2007, 09:12 PM   #11
I sent four samples off to be tested two of the carpet using Sellotape and two of the sills, 3 samples have asbestos in them the one that didnít is one of the carpet samples.
Old 05-24-2007, 06:04 AM   #12
slickshift's Avatar
Oooph....
I hope the painter that removed the popcorn took precautions
Again, if you wet it you can remove it if you want to DIY it
It's the dust that's a hazard-wet it's not
Use "safe room" policies (respirator, gloves, old cloths to be removed when you leave the room, double bag the trash, etc...)
Or, obviously, the safest way is to call in a pro
Old 05-24-2007, 04:17 PM   #13
We will be getting a pro in at the painters expense.
the carpet is what will be hard to clean the pro said it may have to be pulled up.
Old 05-27-2007, 11:31 PM   #14
OSH have been involved they are looking at prosecuting the painter, brand new carpet is being pulled up and the house fully cleaned. Its going to cost around $8,000 for the carpet and house cleaning.
Old 05-28-2007, 07:47 AM   #15
slickshift's Avatar
Holy Moly
Thanks for the update
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Question About Redoing a Popcorn Ceiling... angie59 General DIY Discussions 15 10-16-2008 09:46 AM
popcorn ceiling repair econdave Painting 1 04-14-2007 07:39 PM
Removed ceiling fan, trying to replace w/light fixture-need help Mikedks Electrical 10 09-22-2006 02:00 PM
Question about popcorn ceiling J187 Building & Construction 4 06-30-2006 01:33 PM
