01-14-2013, 07:51 PM
#1
Popcorn ceiling
I just finished removing all my wallpaper and decided that I want the popcorn ceiling removed as well. When I went to a home improvement store to get a scraper and the guy tells me it maybe more trouble than its worth. He starts telling me about the mess it makes, sanding the ceiling, the equipment needed and that the ceiling may not come smooth completely. This is so not why I went that store to get talked out of a project! I don't mind hard work and elbow grease I just need a little advice from some ppl who have removed texture before and hear about their experience. I have the scrapper, tape, eye protection, plastics tarp, mask, water pump and floor covering. I plan on just paint the ceiling once the texture is gone.
Sent from my iPhone
01-14-2013, 07:57 PM
#2
Popcorn ceiling
It will be one of the most worth while improvements you can make.
Not quite as simple as just scrapping it off and painting.
Once it's off most often you'll find where they only did one coat of mud and tape so It's just a matter of doing what ever it takes to get the seams flat.
No amount of paint will fix flaws!
01-14-2013, 08:04 PM
#3
Popcorn ceiling
What does getting the seams flat entail? Sanding?
01-14-2013, 08:13 PM
#4
Popcorn ceiling
Nope, going over it with an 8" wide drywall knife with thined drywall compound.
Apply one thin coat, let it dry, wipe over it with the knife to knock off the high spots, brush with a broom to get the dust off. Go over it again, let it dry.
Now sand the whole ceiling with a sanding pad on a sand pole with screen cloth.
There sold in the drywall area in any box store.
If you can feel a flaw it will show when primed.
Once sanded wipe it down to get the dust off, prime and two coats of ceiling paint.
01-14-2013, 08:15 PM
#5
Popcorn ceiling
Sent from my iPhone
OK first remove anything you can from the room. The one thing the guy was right about is it's messy. Anything that can't be removed needs covered including the floor. Get a pump up vegetable sprayer (a spray bottle just isn"t big enough) fill with water, add about a cup of fabric softener and spray the ceiling, just wet not dripping. Let set about 10 minutes then do it again. Then with a 6" drywall taping knife, nothing bigger, start scrapping. Should come off easy, hold the knife at a pretty good angle so you don't tear the paper on the drywall. Let dry, skim coat any gouges or rough places with ultra light mud, sand. Prime with Gardz sealer, may need to touch up and spot sand again, if so prime again, paint. One thing to mention if you have a ceiling light take it down put wire nuts on the wires and cover with tape. Remember water and sparky don't play well together. In fact just throw the breaker.
01-14-2013, 08:30 PM
#6
Popcorn ceiling
That actually does sound bad. I'm in no rush I just want to do it right.
01-14-2013, 08:33 PM
#7
Popcorn ceiling
It's a small 12 x 10 bathroom so that's not bad
01-14-2013, 11:20 PM
#8
Popcorn ceiling
I meant that doesn't sound bad. Just takes time & patience.
01-14-2013, 11:33 PM
#9
Popcorn ceiling
Rule #1 in DIY repairs never take advice from a box store!
If they knew how to do it they would be.
01-15-2013, 01:06 AM
#10
Deck Staining Pro
Popcorn ceiling
This is the procedure I used in my bathroom and it worked great. You can tell by trying a small area if it will come off easy. In my case the popcorn was never painted which helps and the ceiling underneath was not prepped well so the popcorn fell off easy
Charlie Soden
Apex DeckSavers
"Bringing New life to Old Wood"
The Following User Says Thank You to bigchaz For This Useful Post:
01-15-2013, 06:00 PM
#11
Popcorn ceiling
Depending on the age of the ceiling, you may want to get it tested for asbestos before removing it. Popcorn ceilings installed before about 1980 often have asbestos. Our house was built in 1976, and I thought there was no way it had asbestos, but when we had it tested it did. I'm glad I didn't just go nuts removing it without testing it. My kids would have probably been eating the stuff.
01-15-2013, 07:15 PM
#12
Popcorn ceiling
It was built in 89 so I think I'm good there
01-16-2013, 02:06 AM
#13
JOATMON
Popcorn ceiling
#2 rule in DIY....it's going to be a mess.....
But that's ok....the end result is worth it....
We scraped off the pop corn in our living room...it was put up to hide the 1/4" cracks....we then put up 1/4" sheets of drywall and then covered that with ceiling paper (my wife is English...it's an English thing).
In retrospect, I wish I had just taped and patched the cracks and let the ceiling paper cover up any inperfections.
I suspect that in about 5 years after ALL the other projects are done, I'll rip down the 1/4" drywall, patch the cracks and put up more ceiling paper.
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
01-16-2013, 08:42 AM
#14
Popcorn ceiling
It's worth having it tested for asbestos as you never know. Asbestos was banned from this kind of ceiling treatment in the late 70's but the ban didn't include existing materials and these were still used through the 80's.
Then all you need is a spray bottle of water and a ton of patience
01-16-2013, 08:56 AM
#15
Popcorn ceiling
Just my opinion but I wouldn't go to the trouble or expense of having it tested. You are going to wet it down twice there will be no dust. When you are finished it will be wrapped in plastic. I am not telling you not to do it I"m just saying what I would do.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
