Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 09-11-2008, 05:45 AM   #1
Poorly designed full window in shower/tub wall
Water has rotted at least the window sill and probably deeper. I'm looking for ideas to eliminate this problem, short of removing the window and having to deal with the symmetry problems arising on the exterior. I'd be interested in having help with this; I'm unable to do a decent job. Can you suggest the next step or two?
Thanks,
Donna Lee19
DonnaLee19 is offline   Reply With Quote
Old 09-11-2008, 06:55 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Generally, we advise people (who want to keep a window in that location), to: Order, and install a vinyl window. Order it without window jambs. When installing it in the old window opening, rather than using wood trim work, use PVC composite (non wood) trim. Use it for the window jambs, casings, and apron. When installing the stool (interior sill), pitch it slightly for water drainage. Use mold/mildew resistant caulking. Paint with an exterior grade, mold/mildew resistant paint. If these things are beyond your skill level, consider highering a qualified and experienced carpenter.
Good Luck.
- Build Well -
Window frame not flush with finished wall Stubbie Carpentry 9 06-24-2008 03:38 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Want to install larger window in basement wall andrewcocke Remodeling 8 02-24-2008 11:51 PM
Non-load bearing window header in exterior wall timelyirony Building & Construction 3 12-08-2007 05:15 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
