Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 12-22-2011, 01:03 AM   #1
Pooling water in shutoff
So I just soldered in 2 new shutoffs straight out of the packages. I soldered with them open, then closed them after. After a couple days I noticed water pooling inside them. They have have never been turned on while the main was on. You can see dust on the water surface of one pic.
Are they both bad?
Thanks.
Pooling water in shutoff-image-511231926.jpg   Pooling water in shutoff-image-1066285953.jpg
Wapmiasomey is offline   Reply With Quote
Old 12-22-2011, 10:02 AM   #2
Tileguy
Bud Cline's Avatar
Did you over-heat them and ruin the seals? Are you planning on soldering to them again to complete a circuit?
Old 12-22-2011, 10:47 AM   #3
Maybe I overheated them. It was my very first solder ever and I don't know. I do need to complete the circuit yet.
Old 12-22-2011, 11:34 AM   #4
I may be wrong but those look like tapered gas valves not ones made for water. A water ball valve would be just that a ball inside of it.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Replacing Dishwasher, No water shutoff sustorm Plumbing 24 04-08-2011 01:56 PM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 03:26 PM
Lost Hot water pressure brile Plumbing 11 11-28-2010 03:59 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
