Pool Pump Is Humming - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-12-2013, 04:18 PM   #16
Shandre''s Avatar
So tell me, do u guys just sit online waiting to give advice? Is this a business or a hobby?
Shandre' is offline   Reply With Quote
Old 08-12-2013, 05:11 PM   #17
Just a bunch of very nice people helping their fellow human beings. In my case, working around the home is just a hobby.
But there are many fine pros on this site who give out literally millions of dollars in free advice. They have walked many a person thru complex tasks, only for the satisfaction of helping others. You'll hear from most of them in the evenings, after they get off work.
My hat goes off to them!
RoyalAcresRod is offline   Reply With Quote
The Following 2 Users Say Thank You to RoyalAcresRod For This Useful Post:
gregzoll (08-12-2013), ToolSeeker (08-12-2013)
Old 08-12-2013, 05:28 PM   #18
Rewards Points: 6,652
All of us are home owners, some business owners, others in the trades. But all have homes or property, and pools, so we know what you are going through.
There are some pool forums on the Internet. A couple of good ones, others not so great.
This is the only pool place I can find in your area Tidysites Pool Services C.C
Phone: 078 377 3221
Address: 44 Kotze Street, Hillbrow, Johannesburg, South Africa
Looks like Grainger has a couple of places in Africa http://www.grainger.com/Grainger/static/int_africa.html
I do not know what the company name is for this search for "Pool motor repair" 2 De Ville St, Langlaagte Johannesburg
Phone
011 8375322
Here is another:
Gardenia Street, Alberton 1454, South Africa
Pool pump and Filter repairs/installations
We fit new, replace or repair swimming pool pumps, filter drums and piping on all swimming pools and jacuzzi's. We also install salt chlorinators on jacuzzi's or swimming pools. For a quotation or information please call Wouter on 0834154356 or 0793541351.
Another search result: http://www.alibaba.com/countrysearch/ZA/motor-pump.html
Old 08-12-2013, 11:32 PM   #19
Shandre''s Avatar
Good morning from chilli SA. Wow, thank you so much. I'll give them a call.
The Following User Says Thank You to Shandre' For This Useful Post:
gregzoll (08-13-2013)
Old 08-13-2013, 05:57 AM   #20
Rewards Points: 1,298
When you cleaned out the impeller, was it able to turn freely? A good motor will spin with no power applied.
danpik is offline   Reply With Quote
Old 08-15-2013, 03:48 PM   #21
Shandre''s Avatar
Impeller turned with difficulty. But, when pump was disassembled I got to thinking, "what's the worst that can happen" So I took a big step back and picked up the switch. The motor turned. Churning out grit. But it worked. Unfortunately when i reassembled it hummed that list tune again. Took ur advice. Found a pool shop that does repairs. R150 for bearing, R160 for seals or something and R170 labour .. and I get out back on Monday
Old 08-15-2013, 04:18 PM   #22
So that's about US $48. I think you did good. A lot cheaper than a new one!
The Following User Says Thank You to RoyalAcresRod For This Useful Post:
gregzoll (08-15-2013)
Old 08-15-2013, 04:49 PM   #23
Shandre', make sure that you pass on to others the shop's name, if they do a good job. Also, what kind of warranty are they giving you on the work, and can they make up some shims in case it does not fit level, when you put it back together correct.
At times if the motor is not fitted correctly, being off just a little, will cause more wear on the shaft and bearings, which can cause the problem you got.
Old 08-21-2013, 11:26 AM   #24
Shandre''s Avatar
The company is in Alberton, Johannesburg, South Africa.
With 25 years in the borehole pump industry, Alberton Pumps & Equipment provide pump solutions to various industries and individual clients -
Agricultural Irrigation Equipment (wholesale)
Irrigation Piping
Irrigation Systems & Equipment
Services offered:
*** borehole pumps and accessories
*** irrigation layout and equipment
*** swimming pool pumps and accessories
*** centrifugal pumps
*** booster pumps
Contact Details:
Panorama Building
Cnr Charl Cillers & Eeufees Street
Alberton North
Alberton
Tel: +27 11 907 8845
Fax: +27 11 8692589
Cell: 083 7026589
Email:albpumps@worldonline.co.za
Power 120V Pump from a 240V circuit RoberTX Electrical 26 07-05-2011 11:43 PM
Swimming Pool Pump & Salt Water Ctlr Wiring brianr Electrical 1 06-27-2011 06:02 AM
New pool pump trips breaker?! New home owner needs advice. KenR7A Electrical 22 01-05-2011 09:42 AM
Pool Heat pump ryts4 Electrical 3 04-02-2010 05:53 AM
