Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 09-13-2010, 03:19 PM   #1
Polycarbonate
Does anyone out there have any suggestions on how to remove the protective covering that will not come off from polycarbonate sheets? I have a couple of sheets that the covering is stuck, stuck,stuck and will not peel off. HELP DESPERATELY NEEDED!!
Flavio is offline   Reply With Quote
Old 09-13-2010, 03:46 PM   #2
Polycarbonate
try heating with a hair dryer or heat gun. Then remove the glue residue with alcohol.
RalphPeters is offline   Reply With Quote
Old 09-14-2010, 06:56 AM   #3
Polycarbonate
You might also try paint thinner to soften the adhesive, it won't harm the polycarbonate. Be careful with the heat gun use the coolest setting.
Old 09-14-2010, 11:35 AM   #4
Polycarbonate
Yeah be don't let it be too hot.
You would regret it.
erinra is offline   Reply With Quote
Shower screen - glass vs plexiglass? vsheetz General Discussion 12 12-26-2011 08:26 PM
polycarbonate sheets handifoot Building & Construction 2 10-05-2008 07:08 PM
caulking concrete ctkulig General Discussion 20 05-02-2008 06:03 PM
