Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 02-06-2007, 06:12 PM   #1
Question
Poly on Ground
What does that mean?
K&G's Cabin is offline   Reply With Quote
Old 02-06-2007, 06:49 PM   #2
Home Improvement Guy
ron schenker's Avatar
Poly on Ground
The parrot died?
ron schenker is offline   Reply With Quote
Old 02-06-2007, 06:51 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Poly on Ground
Originally Posted by ron schenker View Post
The parrot died?
Good one...
- Build Well -
Old 02-06-2007, 06:52 PM   #4
Poly on Ground
Sorry....this is in reference to Insulation....
Old 02-06-2007, 06:58 PM   #5
Poly on Ground
Poly:
It's short for: Polyethylene sheeting (Plastic sheeting)
Most common thickness for vapor barriers is 6mm.
- Build Well -
Old 02-06-2007, 07:19 PM   #6
Construction Guru
Poly on Ground
I believe you mean 6 mill, 6 mm would be some heavy stuff, 5/16" thick.
sheeter is offline   Reply With Quote
Old 02-06-2007, 07:22 PM   #7
Poly on Ground
Ya that's 6 thousandth of an inch
Old 02-06-2007, 07:26 PM   #8
Poly on Ground
yep...thanks for catching that...doh...
- Build Well -
Old 02-06-2007, 09:43 PM   #9
remodeling pro
Poly on Ground
It means a sheet of polyethelynene (visqueen) is laid on the ground to form a vapor barrier. It is always installed under a concrete slab and sometimes over bare gound in a crawl space.
troubleseeker is offline   Reply With Quote
Old 02-07-2007, 01:36 PM   #10
Poly on Ground
Originally Posted by troubleseeker View Post
It is always installed under a concrete slab .
Then poked full of holes by the cement guys....
RYANINMICHIGAN is offline   Reply With Quote
12v diff between ground and neutral at panel am9518 Electrical 7 02-25-2008 07:28 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
Electrical ground redline Electrical 12 06-27-2006 08:09 PM
Poly interior doors gregrice Painting 4 05-15-2006 01:35 PM
Proper ground with plastic boxes tjandt Electrical 3 11-07-2005 09:16 AM
