Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 01-08-2006, 10:44 AM   #1
Question
Pocket doors ?
Hi,
I need ideas! I want to replace french doors leading to a sun room with
a pocket door, but do not think I have enough wall space. Also, I think the wall is probably a suppport wall. Does anyone know anything about these doors?
burita
burita is offline   Reply With Quote
Old 01-08-2006, 01:23 PM   #2
Pocket doors ?
Generally 2x the door size you want to use + a couple of inches.If you want 2- 30 in. doors to come together then you would need 60+60+2+2 in. <P>
Sounds like you'll need a header if your pocket door frame is bigger than your original French door rough opening.HS
K2eoj is offline   Reply With Quote
Old 01-08-2006, 10:38 PM   #3
Contractor
Pocket doors ?
On load bearing walls, the supports are usually placed as close as possible to diminish the span.
I would plan on removing a large section of the wall and installing an I-beam to accomplish what you want. The structure will also need to be supported during the renovation. None of this is cheap.
Teetorbilt is offline   Reply With Quote
non pocket sliding doors? jamesdart Remodeling 3 03-07-2009 05:48 PM
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 05:57 PM
outswing patio doors philS Building & Construction 2 07-11-2007 02:39 AM
Attic Doors cyepsen Building & Construction 3 06-24-2007 07:47 AM
Pocket Doors wicklowdesigns@yahoo.com Building & Construction 2 07-06-2005 08:21 AM
