Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 10-01-2011, 07:31 PM   #1
Pocket door frame touching concrete floor question
We are framing our basement which has a concrete floor. All of the walls we've assembled have pressure treated lumber at the base, per code.
We have just put together the pocket door frame and I realized that the frame (wooden) is not treated and is only separated from the concrete floor by a thin strip of metal. How do I resolve this?
I have read that a metal frame from Johnson may've been a wiser move, but is there a way to make what I have work? Can I apply a water seal to it? What will pass inspection and give us the best end result?
Any assistance is appreciated.
-Adam
Adam612 is offline   Reply With Quote
Old 10-01-2011, 07:37 PM   #2
Super Moderator
I've done that several times without a word from an inspector---good luck.
Also---filling in the spaces between the 1x4 nailers withe plywood stiffens up the wall and makes drywalling simpler.
oh'mike is online now   Reply With Quote
Old 10-01-2011, 08:36 PM   #3
I would use some sill foam, that thin pink foam. It would provide a thermal break between concrete and metal and might prevent condensation between metal and wood.
Just my two cents.
Occam's Razor - The simplest answer is probably the correct one.
JCAHILL4 is offline   Reply With Quote
The Following User Says Thank You to JCAHILL4 For This Useful Post:
oh'mike (10-01-2011)
Old 10-01-2011, 09:15 PM   #4
If the metal will be installed in contact to the PT wood, you will need something to isolate the 2 materials.
Ron
B. Franklin 1759
Old 10-02-2011, 10:56 AM   #5
Thanks for all of the quick responses.
If I were to do the foam, would I just apply it under the two small metal plates securing the frame together? About how much material (1/4" thick...) should be applied?
The whole frame is just being pinned to the concrete with a pair of Tapcons. Will that still be sufficient after adding the foam, provided I use a longer Tapcon?
Tags
basement, concrete floor, pocket door, treated
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
How do you measure poured concrete PSI? head_dunce Building & Construction 18 02-25-2007 09:58 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
