Pocket door frame touching concrete floor question
We are framing our basement which has a concrete floor. All of the walls we've assembled have pressure treated lumber at the base, per code.
We have just put together the pocket door frame and I realized that the frame (wooden) is not treated and is only separated from the concrete floor by a thin strip of metal. How do I resolve this? I have read that a metal frame from Johnson may've been a wiser move, but is there a way to make what I have work? Can I apply a water seal to it? What will pass inspection and give us the best end result? Any assistance is appreciated. -Adam |
I've done that several times without a word from an inspector---good luck.
Also---filling in the spaces between the 1x4 nailers withe plywood stiffens up the wall and makes drywalling simpler. |
I would use some sill foam, that thin pink foam. It would provide a thermal break between concrete and metal and might prevent condensation between metal and wood.
Just my two cents. |
If the metal will be installed in contact to the PT wood, you will need something to isolate the 2 materials.
Thanks for all of the quick responses.
If I were to do the foam, would I just apply it under the two small metal plates securing the frame together? About how much material (1/4" thick...) should be applied? The whole frame is just being pinned to the concrete with a pair of Tapcons. Will that still be sufficient after adding the foam, provided I use a longer Tapcon? |
| All times are GMT -4. The time now is 08:48 PM. |
